Tools
Spudger4.9
Introduction
Go to step 1 ↓Follow this guide to replace the upper and/or lower microphones in your Sony DualSense controller.
Note: This guide is for current DualSense controllers with FCC IDs that end with A. Check the back of your controller to verify your model. If yours ends in a 1, it is an early model and there will be internal differences. Follow these guides for the earlier version.
Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
Lift the middle trim over the joysticks to remove it.
Insert the flat end of a spudger into the gap above the L1 button.
Pry the spudger upward to remove the L1 button.
Insert the flat end of a spudger into the gap above the R1 button.
Pry the spudger upward to remove the R1 button.
Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
Use your hands to carefully pull the rear case off of the controller.
Use the pointed end of your spudger to lift the lower microphone out of its bracket next to the battery.
Use the pointed end of your spudger to lift the upper microphone out of the front case.
4 other people completed this guide.
2 Guide Comments
Where do I buy a replacement microphone? I don’t trust eBay, AliBaba, or AliExpress.
fixed my stick drift with this guide, though at the cost of having a “stuck” stick when I move it right, works fine; probably won’t stick back my kontrolfreeks they might wear the contact points faster Anyways other than that issue back to a perfect controller warning though as you can see lots of small intricate parts I recommends some stretching because personally my arms were shaking because I was working with small parts and didn’t want to damage anyhthing. Bellowed oaths and persistence later I succeeded.
