DualSense Controller v2 Joystick Cover Replacement
    1. DualSense Controller v2 Joystick Cover Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
      • Disconnect and power down the controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Ask FixBot
    2. DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    3. DualSense Controller v2 Joystick Cover Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Ask FixBot
    4. DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    5. DualSense Controller v2 Joystick Cover Replacement, Remove the middle trim: step 5, image 1 of 3 DualSense Controller v2 Joystick Cover Replacement, Remove the middle trim: step 5, image 2 of 3 DualSense Controller v2 Joystick Cover Replacement, Remove the middle trim: step 5, image 3 of 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
      Ask FixBot
    1. DualSense Controller v2 Joystick Cover Replacement, Remove the L1 button: step 6, image 1 of 3 DualSense Controller v2 Joystick Cover Replacement, Remove the L1 button: step 6, image 2 of 3 DualSense Controller v2 Joystick Cover Replacement, Remove the L1 button: step 6, image 3 of 3
      • Insert the flat end of a spudger into the gap above the L1 button.
      • Cover the button with your thumb to prevent it from ejecting across the room.
      • Pry the spudger upward to remove the L1 button.
      Ask FixBot
    2. DualSense Controller v2 Joystick Cover Replacement, Remove the R1 button: step 7, image 1 of 3 DualSense Controller v2 Joystick Cover Replacement, Remove the R1 button: step 7, image 2 of 3 DualSense Controller v2 Joystick Cover Replacement, Remove the R1 button: step 7, image 3 of 3
      • Insert the flat end of a spudger into the gap above the R1 button.
      • Pry the spudger upward to remove the R1 button.
      Ask FixBot
    1. DualSense Controller v2 Joystick Cover Replacement, Remove the case screws: step 8, image 1 of 1
      • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
      Ask FixBot
    2. DualSense Controller v2 Joystick Cover Replacement: step 9, image 1 of 1
      • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
      Ask FixBot
    3. DualSense Controller v2 Joystick Cover Replacement, Unclip the rear case: step 10, image 1 of 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the rear case: step 10, image 2 of 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the rear case: step 10, image 3 of 3
      • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
      Ask FixBot
    4. DualSense Controller v2 Joystick Cover Replacement, Remove the rear case: step 11, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement, Remove the rear case: step 11, image 2 of 2
      • Use your hands to carefully pull the rear case off of the controller.
      • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
      Ask FixBot
    1. DualSense Controller v2 Joystick Cover Replacement, Reposition the battery: step 12, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement, Reposition the battery: step 12, image 2 of 2
      • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
      • Don't strain the battery cables.
      Ask FixBot
    2. DualSense Controller v2 Joystick Cover Replacement, Disconnect the battery: step 13, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the battery: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
      • Don't pull on the wires to disconnect the battery.
      Ask FixBot
    3. DualSense Controller v2 Joystick Cover Replacement, Remove the battery: step 14, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. DualSense Controller v2 Joystick Cover Replacement, Remove the lower microphone: step 15, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement, Remove the lower microphone: step 15, image 2 of 2
      • Use the pointed end of a spudger to remove the lower microphone from its bracket next to the battery.
      • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
      Ask FixBot
    2. DualSense Controller v2 Joystick Cover Replacement: step 16, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement: step 16, image 2 of 2
      Buy
      • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
      Ask FixBot
    3. DualSense Controller v2 Joystick Cover Replacement, Remove the battery bracket: step 17, image 1 of 1
      • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
      Ask FixBot
    4. DualSense Controller v2 Joystick Cover Replacement: step 18, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement: step 18, image 2 of 2
      • Lift the battery bracket off of the motherboard.
      Ask FixBot
    5. DualSense Controller v2 Joystick Cover Replacement, Disconnect the right trigger assembly: step 19, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the right trigger assembly: step 19, image 2 of 2
      • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
      • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
      • Don't completely remove the ribbon cable yet.
      Ask FixBot
    6. DualSense Controller v2 Joystick Cover Replacement: step 20, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement: step 20, image 2 of 2
      • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
      • Depending on the controller's model, the ribbon cable may block the motherboard from coming loose. If so, remove the cable from the trigger assembly.
      Ask FixBot
    7. DualSense Controller v2 Joystick Cover Replacement, Disconnect the left trigger assembly: step 21, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the left trigger assembly: step 21, image 2 of 2
      • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
      Ask FixBot
    8. DualSense Controller v2 Joystick Cover Replacement: step 22, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement: step 22, image 2 of 2
      • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
      Ask FixBot
    9. DualSense Controller v2 Joystick Cover Replacement, Disconnect the upper microphone: step 23, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the upper microphone: step 23, image 2 of 2
      • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
      • If you're not replacing this microphone, don't remove it from the frame.
      Ask FixBot
    10. DualSense Controller v2 Joystick Cover Replacement, Disconnect the touchpad: step 24, image 1 of 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the touchpad: step 24, image 2 of 2
      • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
      Ask FixBot
    11. DualSense Controller v2 Joystick Cover Replacement, Lift out the motherboard: step 25, image 1 of 3 DualSense Controller v2 Joystick Cover Replacement, Lift out the motherboard: step 25, image 2 of 3 DualSense Controller v2 Joystick Cover Replacement, Lift out the motherboard: step 25, image 3 of 3
      • Carefully guide the joysticks through the front case and lift the motherboard out.
      • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
      Ask FixBot
    1. DualSense Controller v2 Joystick Cover Replacement, Remove the joystick covers: step 26, image 1 of 3 DualSense Controller v2 Joystick Cover Replacement, Remove the joystick covers: step 26, image 2 of 3 DualSense Controller v2 Joystick Cover Replacement, Remove the joystick covers: step 26, image 3 of 3
      • Use your fingers to pull the joystick covers straight up and off of their modules.
      Ask FixBot
20 other people completed this guide.
Sam Omiotek
100,108 Reputation
289 Guides authored
3 Guide Comments
cant you just glue it.
Joseph Galante - Reply Share
Will it help with stick drifts?
גיא מוסרי - Reply Share
https://www.youtube.com/watch?v=4GLx9I2A...
this saves a lot of hassle and it actually works. I have replaced two sticks with this method by now.
Apfel Wein - Reply Share
Past 24 Hours: 18
Past 7 Days: 180
Past 30 Days: 833
All Time: 26,746
