Up to 20% off select tools
DualSense Controller v2 Button Replacement
Views: 21K
View statistics:
Past 24 Hours:
34
Past 7 Days:
370
Past 30 Days:
1,198
All Time:
20,922
Comments: 12
11 comments on steps, 1 guide comment.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace the buttons in your Sony DualSense controller.
Note: This guide is for current DualSense controllers with FCC IDs that end with A. Check the back of your controller to verify your model. If yours ends in a 1, it is an early model and there will be internal differences. Follow these guides for the earlier version.
Note: Several photos in this guide have been re-used from the Front Cover Replacement guide. The light guide and microphone are shown removed, but do not need to be removed. Follow the procedure as written.
    1. DualSense Controller v2 Button Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 DualSense Controller v2 Button Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
      • Disconnect and power down the controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Ask FixBot
    2. DualSense Controller v2 Button Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 DualSense Controller v2 Button Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 DualSense Controller v2 Button Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    3. DualSense Controller v2 Button Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 DualSense Controller v2 Button Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Ask FixBot
    4. DualSense Controller v2 Button Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 DualSense Controller v2 Button Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 DualSense Controller v2 Button Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    5. DualSense Controller v2 Button Replacement, Remove the middle trim: step 5, image 1 of 3 DualSense Controller v2 Button Replacement, Remove the middle trim: step 5, image 2 of 3 DualSense Controller v2 Button Replacement, Remove the middle trim: step 5, image 3 of 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
      Ask FixBot
    1. DualSense Controller v2 Button Replacement, Remove the L1 button: step 6, image 1 of 3 DualSense Controller v2 Button Replacement, Remove the L1 button: step 6, image 2 of 3 DualSense Controller v2 Button Replacement, Remove the L1 button: step 6, image 3 of 3
      • Insert the flat end of a spudger into the gap above the L1 button.
      • Cover the button with your thumb to prevent it from ejecting across the room.
      • Pry the spudger upward to remove the L1 button.
      Ask FixBot
    2. DualSense Controller v2 Button Replacement, Remove the R1 button: step 7, image 1 of 3 DualSense Controller v2 Button Replacement, Remove the R1 button: step 7, image 2 of 3 DualSense Controller v2 Button Replacement, Remove the R1 button: step 7, image 3 of 3
      • Insert the flat end of a spudger into the gap above the R1 button.
      • Pry the spudger upward to remove the R1 button.
      Ask FixBot
    1. DualSense Controller v2 Button Replacement, Remove the case screws: step 8, image 1 of 1
      • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
      Ask FixBot
    2. DualSense Controller v2 Button Replacement: step 9, image 1 of 1
      • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
      Ask FixBot
    3. DualSense Controller v2 Button Replacement, Unclip the rear case: step 10, image 1 of 3 DualSense Controller v2 Button Replacement, Unclip the rear case: step 10, image 2 of 3 DualSense Controller v2 Button Replacement, Unclip the rear case: step 10, image 3 of 3
      • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
      Ask FixBot
    4. DualSense Controller v2 Button Replacement, Remove the rear case: step 11, image 1 of 2 DualSense Controller v2 Button Replacement, Remove the rear case: step 11, image 2 of 2
      • Use your hands to carefully pull the rear case off of the controller.
      • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
      Ask FixBot
    1. DualSense Controller v2 Button Replacement, Reposition the battery: step 12, image 1 of 2 DualSense Controller v2 Button Replacement, Reposition the battery: step 12, image 2 of 2
      • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
      • Don't strain the battery cables.
      Ask FixBot
    2. DualSense Controller v2 Button Replacement, Disconnect the battery: step 13, image 1 of 2 DualSense Controller v2 Button Replacement, Disconnect the battery: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
      • Don't pull on the wires to disconnect the battery.
      Ask FixBot
    3. DualSense Controller v2 Button Replacement, Remove the battery: step 14, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. DualSense Controller v2 Button Replacement, Remove the lower microphone: step 15, image 1 of 2 DualSense Controller v2 Button Replacement, Remove the lower microphone: step 15, image 2 of 2
      • Use the pointed end of a spudger to remove the lower microphone from its bracket next to the battery.
      • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
      Ask FixBot
    2. DualSense Controller v2 Button Replacement: step 16, image 1 of 2 DualSense Controller v2 Button Replacement: step 16, image 2 of 2
      Buy
      • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
      Ask FixBot
    3. DualSense Controller v2 Button Replacement, Remove the battery bracket: step 17, image 1 of 1
      • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
      Ask FixBot
    4. DualSense Controller v2 Button Replacement: step 18, image 1 of 2 DualSense Controller v2 Button Replacement: step 18, image 2 of 2
      • Lift the battery bracket off of the motherboard.
      Ask FixBot
    5. DualSense Controller v2 Button Replacement, Disconnect the right trigger assembly: step 19, image 1 of 2 DualSense Controller v2 Button Replacement, Disconnect the right trigger assembly: step 19, image 2 of 2
      • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
      • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
      • Don't completely remove the ribbon cable yet.
      Ask FixBot
    6. DualSense Controller v2 Button Replacement: step 20, image 1 of 2 DualSense Controller v2 Button Replacement: step 20, image 2 of 2
      • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
      • Depending on the controller's model, the ribbon cable may block the motherboard from coming loose. If so, remove the cable from the trigger assembly.
      Ask FixBot
    7. DualSense Controller v2 Button Replacement, Disconnect the left trigger assembly: step 21, image 1 of 2 DualSense Controller v2 Button Replacement, Disconnect the left trigger assembly: step 21, image 2 of 2
      • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
      Ask FixBot
    8. DualSense Controller v2 Button Replacement: step 22, image 1 of 2 DualSense Controller v2 Button Replacement: step 22, image 2 of 2
      • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
      Ask FixBot
    9. DualSense Controller v2 Button Replacement, Disconnect the upper microphone: step 23, image 1 of 2 DualSense Controller v2 Button Replacement, Disconnect the upper microphone: step 23, image 2 of 2
      • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
      • If you're not replacing this microphone, don't remove it from the frame.
      Ask FixBot
    10. DualSense Controller v2 Button Replacement, Disconnect the touchpad: step 24, image 1 of 2 DualSense Controller v2 Button Replacement, Disconnect the touchpad: step 24, image 2 of 2
      • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
      Ask FixBot
    11. DualSense Controller v2 Button Replacement, Lift out the motherboard: step 25, image 1 of 3 DualSense Controller v2 Button Replacement, Lift out the motherboard: step 25, image 2 of 3 DualSense Controller v2 Button Replacement, Lift out the motherboard: step 25, image 3 of 3
      • Carefully guide the joysticks through the front case and lift the motherboard out.
      • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
      Ask FixBot
    1. DualSense Controller v2 Button Replacement, Remove the light guide: step 26, image 1 of 3 DualSense Controller v2 Button Replacement, Remove the light guide: step 26, image 2 of 3 DualSense Controller v2 Button Replacement, Remove the light guide: step 26, image 3 of 3
      • Use the pointed end of your spudger to lift the center of the light guide out of the controller.
      • Remove the light guide.
      Ask FixBot
    1. DualSense Controller v2 Button Replacement, Remove the midframe: step 27, image 1 of 1
      • Use your Phillips driver to remove the two 6.5 mm screws securing the midframe to the front case.
      Ask FixBot
    2. DualSense Controller v2 Button Replacement: step 28, image 1 of 3 DualSense Controller v2 Button Replacement: step 28, image 2 of 3 DualSense Controller v2 Button Replacement: step 28, image 3 of 3
      • Carefully lift the midframe and motherboard up and out of the front case.
      • Be careful not to strain the vibrator motor wires.
      • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
      Ask FixBot
    1. DualSense Controller v2 Button Replacement, Remove the Select/Start buttons: step 29, image 1 of 3 DualSense Controller v2 Button Replacement, Remove the Select/Start buttons: step 29, image 2 of 3 DualSense Controller v2 Button Replacement, Remove the Select/Start buttons: step 29, image 3 of 3
      • Remove the Select and Start buttons from the front case.
      Ask FixBot
    2. DualSense Controller v2 Button Replacement, Remove the Mute button: step 30, image 1 of 3 DualSense Controller v2 Button Replacement, Remove the Mute button: step 30, image 2 of 3 DualSense Controller v2 Button Replacement, Remove the Mute button: step 30, image 3 of 3
      • Use your fingers to lightly pinch the plastic clip securing the microphone mute button to the front case and remove it.
      Ask FixBot
    3. DualSense Controller v2 Button Replacement, Remove the conductive silicone: step 31, image 1 of 3 DualSense Controller v2 Button Replacement, Remove the conductive silicone: step 31, image 2 of 3 DualSense Controller v2 Button Replacement, Remove the conductive silicone: step 31, image 3 of 3
      • Remove the three conductive silicone rubber pads from the inside of the front case.
      • The remaining buttons are now resting loose in the front case.
      Ask FixBot
    4. DualSense Controller v2 Button Replacement, Remove the buttons: step 32, image 1 of 3 DualSense Controller v2 Button Replacement, Remove the buttons: step 32, image 2 of 3 DualSense Controller v2 Button Replacement, Remove the buttons: step 32, image 3 of 3
      • Hold the front case close to the surface of your table and slowly turn the front case over to let the buttons fall out.
      • The buttons are designed to be impossible to install incorrectly. Do not force any buttons into place—they will fall into place when positioned correctly.
      Ask FixBot
11 other people completed this guide.
Author
with
Sam Omiotek
101,862 Reputation
289 Guides authored
1 Guide Comment
OK I just did this with my red dualsense and it was actually easier than this. Maybe it is a newer version??? I don't know, but it is different.
If you have the same one as me then do all steps up to, and including, step 18. Then do steps 23 and 24. Remove the two screws in step 27. All the guts will then lift out of the plastic shell, leaving you in a similar situation to step 29.
However, step 11 was difficult for me as the two parts did not simply pull apart. The bottom half came apart easily, but I had to push a thin tool in the top part near the trigger to release an extra clip. Only on one side, then the other side was easy.
Have fun!
token - Reply Share
Past 24 Hours: 34
Past 7 Days: 370
Past 30 Days: 1,198
All Time: 20,922
