DualSense Controller V5 Joystick Covers Replacement
Views: 6.8K
View statistics:
Past 24 Hours:
20
Past 7 Days:
129
Past 30 Days:
595
All Time:
6,805
Comments: 24
23 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow this guide to replace, change, or upgrade the joystick covers in your Sony PlayStation DualSense V5 controller.
Tools
    1. DualSense Controller V5 Joystick Covers Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Ask FixBot
    2. DualSense Controller V5 Joystick Covers Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 DualSense Controller V5 Joystick Covers Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 DualSense Controller V5 Joystick Covers Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    3. DualSense Controller V5 Joystick Covers Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Ask FixBot
    4. DualSense Controller V5 Joystick Covers Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 DualSense Controller V5 Joystick Covers Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 DualSense Controller V5 Joystick Covers Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    5. DualSense Controller V5 Joystick Covers Replacement, Remove the middle trim: step 5, image 1 of 3 DualSense Controller V5 Joystick Covers Replacement, Remove the middle trim: step 5, image 2 of 3 DualSense Controller V5 Joystick Covers Replacement, Remove the middle trim: step 5, image 3 of 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      Ask FixBot
    1. DualSense Controller V5 Joystick Covers Replacement, Remove the L1 button: step 6, image 1 of 3 DualSense Controller V5 Joystick Covers Replacement, Remove the L1 button: step 6, image 2 of 3 DualSense Controller V5 Joystick Covers Replacement, Remove the L1 button: step 6, image 3 of 3
      • With one hand, grip the controller and use your thumb to hold down the left trigger.
      • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
      • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
      Ask FixBot
    2. DualSense Controller V5 Joystick Covers Replacement, Remove the R1 button: step 7, image 1 of 3 DualSense Controller V5 Joystick Covers Replacement, Remove the R1 button: step 7, image 2 of 3 DualSense Controller V5 Joystick Covers Replacement, Remove the R1 button: step 7, image 3 of 3
      • Repeat the previous step to remove the R1 button.
      Ask FixBot
    1. DualSense Controller V5 Joystick Covers Replacement, Remove the rear case screws: step 8, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement, Remove the rear case screws: step 8, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
      Ask FixBot
    2. DualSense Controller V5 Joystick Covers Replacement: step 9, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
      Ask FixBot
    3. DualSense Controller V5 Joystick Covers Replacement, Separate the rear case: step 10, image 1 of 3 DualSense Controller V5 Joystick Covers Replacement, Separate the rear case: step 10, image 2 of 3 DualSense Controller V5 Joystick Covers Replacement, Separate the rear case: step 10, image 3 of 3
      • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
      • Use the point of a spudger to release the two clips on either side of the headset jack.
      Ask FixBot
    4. DualSense Controller V5 Joystick Covers Replacement: step 11, image 1 of 3 DualSense Controller V5 Joystick Covers Replacement: step 11, image 2 of 3 DualSense Controller V5 Joystick Covers Replacement: step 11, image 3 of 3
      • Tight plastic clips secure the left and right edges of the rear case.
      • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
      • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
      Ask FixBot
    5. DualSense Controller V5 Joystick Covers Replacement: step 12, image 1 of 3 DualSense Controller V5 Joystick Covers Replacement: step 12, image 2 of 3 DualSense Controller V5 Joystick Covers Replacement: step 12, image 3 of 3
      • Repeat the previous step on the right edge to release its clips.
      Ask FixBot
    6. DualSense Controller V5 Joystick Covers Replacement: step 13, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement: step 13, image 2 of 2
      • Lay your controller upside down so the joysticks are on your work surface.
      • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
      Ask FixBot
    1. DualSense Controller V5 Joystick Covers Replacement, Remove the rear case: step 14, image 1 of 1
      • Remove the rear case.
      Ask FixBot
    1. DualSense Controller V5 Joystick Covers Replacement, Disconnect the battery: step 15, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement, Disconnect the battery: step 15, image 2 of 2
      • Don't try to fully remove the battery, as it's still connected to the controller by delicate cables.
      • Swing the battery out of its recess so you can access its connector, making sure to not strain the cables.
      • Keep the battery supported so it doesn't fall during the next step.
      Ask FixBot
    2. DualSense Controller V5 Joystick Covers Replacement: step 16, image 1 of 3 DualSense Controller V5 Joystick Covers Replacement: step 16, image 2 of 3 DualSense Controller V5 Joystick Covers Replacement: step 16, image 3 of 3
      • Use a pair of angled tweezers to firmly grip the short sides of the battery connector.
      • To get a stronger hold on the connector, grip the tweezers as close to the connector as you can.
      • Rock the connector side‑to‑side to walk it out of its socket and disconnect it.
      Ask FixBot
    3. DualSense Controller V5 Joystick Covers Replacement, Remove the battery: step 17, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. DualSense Controller V5 Joystick Covers Replacement, Remove the lower microphone: step 18, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement, Remove the lower microphone: step 18, image 2 of 2
      • Use tweezers to grip the lower microphone cable's plastic tab and pull it straight out of the socket to remove the microphone.
      • During reassembly, make sure the microphone has its rubber gasket and that the alignment tab goes into its cutout.
      Ask FixBot
    2. DualSense Controller V5 Joystick Covers Replacement, Remove the battery bracket: step 19, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement, Remove the battery bracket: step 19, image 2 of 2
      • Use a Phillips screwdriver to remove the 6.5 mm‑long screw securing the battery bracket.
      Ask FixBot
    3. DualSense Controller V5 Joystick Covers Replacement: step 20, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement: step 20, image 2 of 2
      • Remove the battery bracket.
      Ask FixBot
    4. DualSense Controller V5 Joystick Covers Replacement, Disconnect the motherboard: step 21, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement, Disconnect the motherboard: step 21, image 2 of 2
      • Use tweezers to grip the hard plastic section of the right trigger ribbon cable and pull the cable straight out of its socket to disconnect it.
      • If you're having trouble, try gripping the tweezers as close to the cable as possible to get a better hold.
      Ask FixBot
    5. DualSense Controller V5 Joystick Covers Replacement: step 22, image 1 of 3 DualSense Controller V5 Joystick Covers Replacement: step 22, image 2 of 3 DualSense Controller V5 Joystick Covers Replacement: step 22, image 3 of 3
      Ask FixBot
    6. DualSense Controller V5 Joystick Covers Replacement, Reposition the motherboard: step 23, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement, Reposition the motherboard: step 23, image 2 of 2
      • Throughout the rest of your repair, be very careful not to strain the delicate wires attached to the bottom edge of the board. They can easily tear, requiring soldering to fix them.
      • Use your fingers to gently push the joysticks through their cutouts on the shell to separate the motherboard.
      Ask FixBot
    7. DualSense Controller V5 Joystick Covers Replacement: step 24, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement: step 24, image 2 of 2
      • Carefully flip the motherboard down so the joysticks are facing up.
      Ask FixBot
    1. DualSense Controller V5 Joystick Covers Replacement, Speaker note: step 25, image 1 of 2 DualSense Controller V5 Joystick Covers Replacement, Speaker note: step 25, image 2 of 2
      • The speaker may have fallen out when repositioning the motherboard. If it did, set it aside for reassembly. If it stayed in place on the motherboard or is in its recess in the front case, you can leave it in place.
      • During reassembly, place the speaker in its recess so the foam pad is on the left and the spring contacts are on the right.
      Ask FixBot
    1. DualSense Controller V5 Joystick Covers Replacement, Remove the joystick covers: step 26, image 1 of 3 DualSense Controller V5 Joystick Covers Replacement, Remove the joystick covers: step 26, image 2 of 3 DualSense Controller V5 Joystick Covers Replacement, Remove the joystick covers: step 26, image 3 of 3
      • Secure the motherboard with one hand, and use your free hand to pull the joystick covers straight up to remove them.
      Ask FixBot
3 other people completed this guide.
Spencer Day
207,676 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
1 Guide Comment
Great walk through. It was slightly difficult removing the upper part of the shell. Luckily didn't break it. Thanks for posting these guides 👍
Simon Salamina - Reply Share
Past 24 Hours: 20
Past 7 Days: 129
Past 30 Days: 595
All Time: 6,805
