Dual BT 10 Mainboard Disassembly
    1. Dual BT 10 Mainboard Disassembly, Removing bottom screws: step 1, image 1 of 3 Dual BT 10 Mainboard Disassembly, Removing bottom screws: step 1, image 2 of 3 Dual BT 10 Mainboard Disassembly, Removing bottom screws: step 1, image 3 of 3
      • Unplug the device if needed and put the power switch into the "OFF" position.
      • Turn the device upside down
      • Remove the two foam feet at the front end of the speaker (the end with the buttons)
      • Unscrew the two screws revealed by the foam pads
      Ask FixBot
    2. Dual BT 10 Mainboard Disassembly, Removing the top screw: step 2, image 1 of 3 Dual BT 10 Mainboard Disassembly, Removing the top screw: step 2, image 2 of 3 Dual BT 10 Mainboard Disassembly, Removing the top screw: step 2, image 3 of 3
      • Turn the device in its normal position (standing on the foam feet)
      • Remove the screw cover using a thin blade at the front end of the device (the end with the buttons)
      • Unscrew the screw and remove it together with its plastic seating
      Ask FixBot
    3. Dual BT 10 Mainboard Disassembly, Removing the front housing: step 3, image 1 of 2 Dual BT 10 Mainboard Disassembly, Removing the front housing: step 3, image 2 of 2
      • Gently pull the rubber strap to remove it from the silver front housing
      • Pull the silver front housing from the main body of the device
      • Do so gently as some cables are still connected inside the housing
      Ask FixBot
    4. Dual BT 10 Mainboard Disassembly, Disconnecting the components: step 4, image 1 of 2 Dual BT 10 Mainboard Disassembly, Disconnecting the components: step 4, image 2 of 2
      • Disconnect all cables:
      • Take a picture of how everything is plugged in to make reassembling easier
      • Disconnect the battery first (fat red/black cable, red socket)
      • Disconnect the two front speakers (blue/white cables)
      • Disconnect the Subwoofer and LED cable (brown/black, red/black cables)
      Ask FixBot
    5. Dual BT 10 Mainboard Disassembly, Removing the antenna wire: step 5, image 1 of 1
      • Remove the red antenna wire by loosening it from the marked plastic taps
      Ask FixBot
    6. Dual BT 10 Mainboard Disassembly, Unscrewing the front mesh: step 6, image 1 of 3 Dual BT 10 Mainboard Disassembly, Unscrewing the front mesh: step 6, image 2 of 3 Dual BT 10 Mainboard Disassembly, Unscrewing the front mesh: step 6, image 3 of 3
      • Remove the four screws holding the front mesh
      • Separate the black plastic from the silver part
      • There is a cable connecting both parts! Be careful.
      • The mainboard is not screwed in place and will be loose after this step
      • Disconnect the brown cable from the small PCB to fully remove the black plastic
      Ask FixBot
    7. Dual BT 10 Mainboard Disassembly, Removing the main board: step 7, image 1 of 1
      • Pull out the main board from the assembly
      • Carefully feed the antenna wire through its small hole if needed
      Ask FixBot
    8. Dual BT 10 Mainboard Disassembly, Reassembly: step 8, image 1 of 1
      • To reassemble the device, follow all steps in reverse order
      • When reinserting the motherboard, be careful to place it inside the plastic guides in the black plastic / mesh cover
      • When pluging in all cables, it is recommended to plug in the battery last (thick red/black cable, red socket)
      Ask FixBot
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Skyfighter
439 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 33
All Time: 644
