Up to 20% off select tools
Droid Ultra XT1080 Power Button Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
59
All Time:
863
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to properly replace the power button on your Motorola Droid Ultra XT 1080
    1. Droid Ultra XT1080 Power Button Replacement, Power Button: step 1, image 1 of 3 Droid Ultra XT1080 Power Button Replacement, Power Button: step 1, image 2 of 3 Droid Ultra XT1080 Power Button Replacement, Power Button: step 1, image 3 of 3
      • Gently remove the SIM card tray from the device using a spudger.
      Ask FixBot
    2. Droid Ultra XT1080 Power Button Replacement: step 2, image 1 of 1
      • After SIM card removal press the spudger between the plastic case and the frame until you hear a snap.
      • Work your way around the device until all the clips are released.
      • Be gentle while doing this so you don't crack or break the plastic.
      Ask FixBot
    3. Droid Ultra XT1080 Power Button Replacement: step 3, image 1 of 1
      • Remove the five screws on top of the device with a T5 Torx.
      • Remove the single screw holding the camera with a T4 Torx.
      • Remove the two screws on the bottom of the device with a T5 Torx.
      Ask FixBot
    4. Droid Ultra XT1080 Power Button Replacement: step 4, image 1 of 2 Droid Ultra XT1080 Power Button Replacement: step 4, image 2 of 2
      • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
      Ask FixBot
    5. Droid Ultra XT1080 Power Button Replacement: step 5, image 1 of 1
      • Remove the four T5 Torx screws securing the motherboard.
      Ask FixBot
    6. Droid Ultra XT1080 Power Button Replacement: step 6, image 1 of 1
      • Gently pry the motherboard out of the frame using the plastic opening tool.
      Ask FixBot
    7. Droid Ultra XT1080 Power Button Replacement: step 7, image 1 of 2 Droid Ultra XT1080 Power Button Replacement: step 7, image 2 of 2
      Tool used on this step:
      $3.99
      Buy
      • Once motherboard is removed you have gained access to the power button.
      • Gently, using a pair of angled tweezers pull on the power button to remove it.
      Ask FixBot
Author
with
knoyes
785 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 59
All Time: 863
