Droid Ultra XT1080 Charging Port Replacement
    1. Droid Ultra XT1080 Charging Port  Replacement, Charging Port: step 1, image 1 of 1
      • Remove SIM card tray from the device with a plastic opening tool.
      Ask FixBot
    2. Droid Ultra XT1080 Charging Port  Replacement: step 2, image 1 of 1
      • Once SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
      • Work your away around the device until all the plastic clips are undone.
      • Be gentle with the plastic to make sure it doesn't break.
      Ask FixBot
    3. Droid Ultra XT1080 Charging Port  Replacement: step 3, image 1 of 1
      • Remove the five screws on top of the device with a T5 Torx.
      • Remove the single screw holding the camera with a T4 Torx.
      • Remove the two screws on the bottom of the device with a T5 Torx.
      Ask FixBot
    4. Droid Ultra XT1080 Charging Port  Replacement: step 4, image 1 of 2 Droid Ultra XT1080 Charging Port  Replacement: step 4, image 2 of 2
      • Once the screws are removed, use a plastic spudger and lift up the two plastic pieces that were secured by the screws.
      Ask FixBot
    5. Droid Ultra XT1080 Charging Port  Replacement: step 5, image 1 of 1
      • Remove the four T5 Torx screws securing the motherboard.
      Ask FixBot
    6. Droid Ultra XT1080 Charging Port  Replacement: step 6, image 1 of 1
      • Gently pry the motherboard out of the frame of the device.
      Ask FixBot
    7. Droid Ultra XT1080 Charging Port  Replacement: step 7, image 1 of 2 Droid Ultra XT1080 Charging Port  Replacement: step 7, image 2 of 2
      • Once the motherboard is free flip it over on its back so all the components are showing.
      Ask FixBot
    8. Droid Ultra XT1080 Charging Port  Replacement: step 8, image 1 of 1
      • To fully replace the charging port you need to desolder the port and solder a new one in.
      Ask FixBot
knoyes
785 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 60
All Time: 1,343
