Droid Ultra XT1080 Battery Replacement
    1. Droid Ultra XT1080 Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the SIM card tray from the side of the device using a plastic opening tool.
      Ask FixBot
    2. Droid Ultra XT1080 Battery Replacement: step 2, image 1 of 1
      • After properly removing the SIM card tray take your spudger and press it in between the plastic case and the frame of the device until you hear a snap.
      • Work your way from the top and the other side to confirm all the clips are disconnected.
      • Be gentle when performing this so you don't crack or break the plastic.
      Ask FixBot
    3. Droid Ultra XT1080 Battery Replacement: step 3, image 1 of 1
      • Remove the five screws on top of the device with a T5 Torx.
      • Remove the single screw holding the camera with a T4 Torx.
      • Remove the two screws on the bottom of the device with a T5 Torx.
      Ask FixBot
    4. Droid Ultra XT1080 Battery Replacement: step 4, image 1 of 2 Droid Ultra XT1080 Battery Replacement: step 4, image 2 of 2
      • After the top and bottom screws are removed remove the top and bottom plastic pieces that were secured to the device.
      Ask FixBot
    5. Droid Ultra XT1080 Battery Replacement: step 5, image 1 of 1
      • Begin to gently pry up the battery from the frame with a plastic opening tool to release it from its adhesive securing.
      Ask FixBot
    6. Droid Ultra XT1080 Battery Replacement: step 6, image 1 of 1
      • Remove the four T5 Torx screws securing the motherboard.
      Ask FixBot
    7. Droid Ultra XT1080 Battery Replacement: step 7, image 1 of 2 Droid Ultra XT1080 Battery Replacement: step 7, image 2 of 2
      • Gently pry the motherboard out of the frame using the nylon spudger.
      • Make sure not to damage the LCD cable in the process.
      Ask FixBot
    8. Droid Ultra XT1080 Battery Replacement: step 8, image 1 of 1
      • Disconnect the LCD cable with a spudger from the motherboard by gently lifting up the two connectors.
      Ask FixBot
3 other people completed this guide.
knoyes
785 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 73
All Time: 3,589
