Up to 20% off select tools
Droid MAXX 2 Screen Assembly Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
59
All Time:
2,595
Comments: 7
7 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
  • Spudger
    4.9
  • Tweezers
  • T4 Torx Screwdriver
    4.8
Introduction
Go to step 1 ↓
This guide show how to replace the screen of the Motorola Droid MAXX 2 smartphone.
    1. Droid MAXX 2 Screen Assembly  Replacement, Battery: step 1, image 1 of 1
      • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
      Ask FixBot
    2. Droid MAXX 2 Screen Assembly  Replacement: step 2, image 1 of 1
      • Pull the sim card tray up out of the phone
      Ask FixBot
    3. Droid MAXX 2 Screen Assembly  Replacement: step 3, image 1 of 2 Droid MAXX 2 Screen Assembly  Replacement: step 3, image 2 of 2
      • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
      Ask FixBot
    4. Droid MAXX 2 Screen Assembly  Replacement: step 4, image 1 of 1
      • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
      • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
      Ask FixBot
    5. Droid MAXX 2 Screen Assembly  Replacement: step 5, image 1 of 1
      • Pull the mid-frame off of the phone.
      • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
      Ask FixBot
    6. Droid MAXX 2 Screen Assembly  Replacement: step 6, image 1 of 3 Droid MAXX 2 Screen Assembly  Replacement: step 6, image 2 of 3 Droid MAXX 2 Screen Assembly  Replacement: step 6, image 3 of 3
      • Remove the static tape covering the two connectors.
      • Use a spudger to disconnect the battery cables from the motherboard.
      • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
      Ask FixBot
    7. Droid MAXX 2 Screen Assembly  Replacement: step 7, image 1 of 1
      • Remove the disconnected battery from the phone.
      Ask FixBot
    1. Droid MAXX 2 Screen Assembly  Replacement, Screen Assembly: step 8, image 1 of 2 Droid MAXX 2 Screen Assembly  Replacement, Screen Assembly: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • We will be removing these 3 ribbon cables.
      • Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
      • Use tweezers to lift up on the grey latch on the ZIF connector.
      • Remove the ribbon cable from the ZIF connector.
      Ask FixBot
    2. Droid MAXX 2 Screen Assembly  Replacement: step 9, image 1 of 2 Droid MAXX 2 Screen Assembly  Replacement: step 9, image 2 of 2
      • Use a pair of tweezers to lift up the black latch on the ZIF connector.
      • Pull the ribbon cable out of the ZIF connector.
      Ask FixBot
    3. Droid MAXX 2 Screen Assembly  Replacement: step 10, image 1 of 3 Droid MAXX 2 Screen Assembly  Replacement: step 10, image 2 of 3 Droid MAXX 2 Screen Assembly  Replacement: step 10, image 3 of 3
      • Using a metal spudger, work your way around the perimeter of the main board and screen.
      • There is a lot of adhesive between the two pieces, so be careful to try to remove the adhesive slowly in order to not break anything.
      Ask FixBot
2 other people completed this guide.
Author
with
Burke Seggerman
704 Reputation
5 Guides authored
Baylor, Team S3-G4, Williams Spring 2018 Member of Baylor, Team S3-G4, Williams Spring 2018
BU-WILLIAMS-S18S3G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 59
All Time: 2,595
