Drobo FS DRDS2-A Power Switch Replacement
Views: 3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
89
All Time:
3,008
Comments: 5
5 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
How to replace the Power Switch
Parts
Tools
    1. Drobo FS DRDS2-A Power Switch Replacement, Case: step 1, image 1 of 1
      • To start getting the case off remove the front panel so it's out of the way.
      Ask FixBot
    2. Drobo FS DRDS2-A Power Switch Replacement: step 2, image 1 of 2 Drobo FS DRDS2-A Power Switch Replacement: step 2, image 2 of 2
      • Next remove the screws from the feet of the case with a phillips head screwdriver.
      Ask FixBot
    3. Drobo FS DRDS2-A Power Switch Replacement: step 3, image 1 of 1
      • To remove the case, place the Drobo on its back and slide the case off.
      Ask FixBot
    1. Drobo FS DRDS2-A Power Switch Replacement, Power Switch: step 4, image 1 of 3 Drobo FS DRDS2-A Power Switch Replacement, Power Switch: step 4, image 2 of 3 Drobo FS DRDS2-A Power Switch Replacement, Power Switch: step 4, image 3 of 3
      • Press tabs to release back cover and lift off
      Ask FixBot
    2. Drobo FS DRDS2-A Power Switch Replacement: step 5, image 1 of 2 Drobo FS DRDS2-A Power Switch Replacement: step 5, image 2 of 2
      • Push tabs in and carefully pull out the front facer and drive shelves
      Ask FixBot
    3. Drobo FS DRDS2-A Power Switch Replacement: step 6, image 1 of 2 Drobo FS DRDS2-A Power Switch Replacement: step 6, image 2 of 2
      • Unscrew the back face by removing the screw on the back sides, then slide top face apart from the others
      • If you have a Drobo 5N2, you may also need to remove the 3 screws on each side.
      Ask FixBot
    4. Drobo FS DRDS2-A Power Switch Replacement: step 7, image 1 of 2 Drobo FS DRDS2-A Power Switch Replacement: step 7, image 2 of 2
      • Carefully unplug the Power Switch and Fan wires.
      Ask FixBot
    5. Drobo FS DRDS2-A Power Switch Replacement: step 8, image 1 of 1
      • Press tabs on Power Switch to release the Power Switch and Push out.
      • A Spudger like object is helpful for pushing in the tabs if the fan is not removed also
      Ask FixBot
    6. Drobo FS DRDS2-A Power Switch Replacement: step 9, image 1 of 2 Drobo FS DRDS2-A Power Switch Replacement: step 9, image 2 of 2
      • Finally pull the old switch out and pop the new one in.
      Ask FixBot
3 other people completed this guide.
Rye Cassan
182 Reputation
1 Guide authored
Cal Poly, Team 10-4, Banghart Winter 2017 Member of Cal Poly, Team 10-4, Banghart Winter 2017
CPSU-BANGHART-W17S10G4
3 Members
60 Guides authored
5 Guide Comments
Hello,
great info I found here, but where do I buy a replacement button for my Drobo in Europe?
Kind regards and thank you in advance,
Heinrich
Heinrich Voelkel - Reply Share
Hi, where do I find a replacement power switch for my Drobo 5N? BTW, thanks for the great tutorial!
Stephen R Parrott - Reply Share
I took my Drobo apart and the printed numbers on the switch are R13-112. I ordered these on Amazon:
https://www.amazon.com/Twidec-Rocker-Tog...
I put it in, crossed my fingers, and BAM, worked like a charm. Hope that helps all the future DIY’ers.
tdubs - Reply Share
Good article - thanks. Discovered my Drobo 5N (cir 2014) has a 3-wire spring-loaded switch with 2V LED (green) (wires: Red - White - Blue) Press once to turn on; Press and hold to manually turn off. Can simple R13-112 SPST switch be substituted?
John W - Reply Share
Many thanks Rye. My Drobo 5C switch has been playing up for a while and your article gave me the courage to tackle the issue. A few dirfferences for the 5C (removing the back panel) but otherwise all tickety boo.
Maarten van der Kleij - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 89
All Time: 3,008
