Drill Master Heat Gun Power Switch Replacement
    1. Drill Master Heat Gun Power Switch Replacement, Power Switch: step 1, image 1 of 1
      • Be sure the heat gun is unplugged before starting this process.
      • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
      • You will need a screwdriver extension.
      Ask FixBot
    2. Drill Master Heat Gun Power Switch Replacement: step 2, image 1 of 1
      • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
      • Don't try to open the casing just yet.
      Ask FixBot
    3. Drill Master Heat Gun Power Switch Replacement: step 3, image 1 of 3 Drill Master Heat Gun Power Switch Replacement: step 3, image 2 of 3 Drill Master Heat Gun Power Switch Replacement: step 3, image 3 of 3
      • Remove the barrel casing on either end by twisting and pulling each side off.
      Ask FixBot
    4. Drill Master Heat Gun Power Switch Replacement: step 4, image 1 of 1
      • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
      Ask FixBot
    5. Drill Master Heat Gun Power Switch Replacement: step 5, image 1 of 1
      • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
      • Screws do not come out of connector.
      Ask FixBot
    6. Drill Master Heat Gun Power Switch Replacement: step 6, image 1 of 1
      • Squeeze the tabs on either side of the power switch to remove from the casing.
      Ask FixBot
    7. Drill Master Heat Gun Power Switch Replacement: step 7, image 1 of 2 Drill Master Heat Gun Power Switch Replacement: step 7, image 2 of 2
      • Remove the black, plastic wire protectors from the end of the power switch.
      Ask FixBot
    8. Drill Master Heat Gun Power Switch Replacement: step 8, image 1 of 1
      • Use soldering iron to remove the electrical wiring from the power switch. To replace the power switch, solder the new switch onto the wires.
      • Heating the soldering metal will allow you to pull off the electrical wiring.
      • For a brush-up on proper soldering, check out How to Solder and Desolder Connections.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 53
All Time: 4,011
