Drill Master Heat Gun Motor Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
103
All Time:
2,631
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
The motor inside the barrel of the gun powers the fan. Use this guide to replace the motor.
Tools
    1. Drill Master Heat Gun Motor Replacement, Motor: step 1, image 1 of 1
      • Be sure the heat gun is unplugged before starting this process.
      • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
      • You will need a screwdriver extension.
      Ask FixBot
    2. Drill Master Heat Gun Motor Replacement: step 2, image 1 of 1
      • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
      • Don't try to open the casing just yet.
      Ask FixBot
    3. Drill Master Heat Gun Motor Replacement: step 3, image 1 of 3 Drill Master Heat Gun Motor Replacement: step 3, image 2 of 3 Drill Master Heat Gun Motor Replacement: step 3, image 3 of 3
      • Remove the barrel casing on either end by twisting and pulling each side off.
      Ask FixBot
    4. Drill Master Heat Gun Motor Replacement: step 4, image 1 of 1
      • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
      Ask FixBot
    5. Drill Master Heat Gun Motor Replacement: step 5, image 1 of 1
      • Remove the metal casing and fan cover from the fan unit.
      Ask FixBot
    6. Drill Master Heat Gun Motor Replacement: step 6, image 1 of 1
      • Bend the metal prongs backward that connect the fan motor to the plastic cap.
      • Bending the brackets too far back can cause the brackets to break.
      Ask FixBot
    7. Drill Master Heat Gun Motor Replacement: step 7, image 1 of 1
      • Remove the plastic cap from the motor,
      • This will allow you to work only with the motor and fan.
      Ask FixBot
    8. Drill Master Heat Gun Motor Replacement: step 8, image 1 of 1
      • Remove the fan by pulling it from the motor rod.
      Ask FixBot
    9. Drill Master Heat Gun Motor Replacement: step 9, image 1 of 1
      • Remove the two 12mm screws from the plastic fan casing using PH#00
      Ask FixBot
    10. Drill Master Heat Gun Motor Replacement: step 10, image 1 of 1
      • Remove the plastic fan casing.
      Ask FixBot
    11. Drill Master Heat Gun Motor Replacement: step 11, image 1 of 1
      • Remove the metal casing from the motor and insert the new motor in its place.
      • You may have to tug a little.
      Ask FixBot
1 Guide Comment
Where can I find a new motor?
jstabler38 - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 103
All Time: 2,631
