Drill Master Heat Gun Fan Replacement
    1. Drill Master Heat Gun Fan Replacement, Fan: step 1, image 1 of 1
      • Be sure the heat gun is unplugged before starting this process.
      • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
      • You will need a screwdriver extension.
      Ask FixBot
    2. Drill Master Heat Gun Fan Replacement: step 2, image 1 of 1
      • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
      • Don't try to open the casing just yet.
      Ask FixBot
    3. Drill Master Heat Gun Fan Replacement: step 3, image 1 of 3 Drill Master Heat Gun Fan Replacement: step 3, image 2 of 3 Drill Master Heat Gun Fan Replacement: step 3, image 3 of 3
      • Remove the barrel casing on either end by twisting and pulling each side off.
      Ask FixBot
    4. Drill Master Heat Gun Fan Replacement: step 4, image 1 of 1
      • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
      Ask FixBot
    5. Drill Master Heat Gun Fan Replacement: step 5, image 1 of 1
      • Remove the metal casing and fan cover from the fan unit.
      Ask FixBot
    6. Drill Master Heat Gun Fan Replacement: step 6, image 1 of 1
      • Bend the metal prongs backward that connect the fan motor to the plastic cap.
      • Bending the brackets too far back can cause the brackets to break.
      Ask FixBot
    7. Drill Master Heat Gun Fan Replacement: step 7, image 1 of 1
      • Remove the plastic cap from the motor,
      • This will allow you to work only with the motor and fan.
      Ask FixBot
    8. Drill Master Heat Gun Fan Replacement: step 8, image 1 of 1
      • Remove the fan by pulling it from the motor rod and replace.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 55
All Time: 4,037
