Up to 20% off select tools
Dresser Drawer Guide Tracks Replacement
Views: 5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
38
Past 30 Days:
185
All Time:
5,040
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Very easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
If your dresser drawer isn’t sliding in and out properly or if it is getting stuck, you may need to replace the metal tracks. Use this guide to replace the metal tracks in your dresser drawer.
    1. Dresser Drawer Guide Tracks Replacement, Broken Guide Tracks for a Dresser Drawer: step 1, image 1 of 2 Dresser Drawer Guide Tracks Replacement, Broken Guide Tracks for a Dresser Drawer: step 1, image 2 of 2
      • As you can see, the guide tracks that set the drawer in place are no longer attached to the dresser in the correct position.
      Ask FixBot
    2. Dresser Drawer Guide Tracks Replacement: step 2, image 1 of 1
      • You will need super glue and a staple gun because the dresser and the tracks are wooden. You can also use screws and a screwdriver if you would like.
      Ask FixBot
    3. Dresser Drawer Guide Tracks Replacement: step 3, image 1 of 1
      • Apply the glue to both sides on the wooden tracks. You will only need a small amount.
      Ask FixBot
    4. Dresser Drawer Guide Tracks Replacement: step 4, image 1 of 2 Dresser Drawer Guide Tracks Replacement: step 4, image 2 of 2
      • Now you will want to place the tracks in the desired location inside the dresser. You will want to apply pressure from the top of the track to secure the clue to the wood. Let this dry for about 5-10 minutes.
      Ask FixBot
    5. Dresser Drawer Guide Tracks Replacement: step 5, image 1 of 2 Dresser Drawer Guide Tracks Replacement: step 5, image 2 of 2
      • Once your clue has dried, you can now use the staple gun to ensure that the track is secure.
      Ask FixBot
    6. Dresser Drawer Guide Tracks Replacement: step 6, image 1 of 2 Dresser Drawer Guide Tracks Replacement: step 6, image 2 of 2
      • Finally, once the tracks have been set and are secure, you can align your drawer to the tracks and slide the drawer back into the dresser.
      Ask FixBot
Finish Line
Author
with
jackson feld
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 185
All Time: 5,040
