Up to 20% off select tools
Dress Shirt Button Replacement
Views: 6.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
41
Past 30 Days:
176
All Time:
6,069
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Sometimes buttons can fall off dress shirts over time. Don't just throw yours away. Replace it! Use this guide to learn on to replace one so that they can be worn again.
    1. Dress Shirt Button Replacement, Button: step 1, image 1 of 2 Dress Shirt Button Replacement, Button: step 1, image 2 of 2
      • Measure out two feet of thread and cut it.
      Ask FixBot
    2. Dress Shirt Button Replacement: step 2, image 1 of 3 Dress Shirt Button Replacement: step 2, image 2 of 3 Dress Shirt Button Replacement: step 2, image 3 of 3
      • The needle is sharp. Be careful when working.
      • Put the thread through the eye of the needle.
      • Pull the thread through so that both ends are even.
      • Tie both strings into a knot, closing the loop
      Ask FixBot
    3. Dress Shirt Button Replacement: step 3, image 1 of 2 Dress Shirt Button Replacement: step 3, image 2 of 2
      • Begin sewing by putting the needle through the back of the fabric, out to the front, and through a hole in the button.
      • Make sure the button is facing the correct direction.
      Ask FixBot
    4. Dress Shirt Button Replacement: step 4, image 1 of 3 Dress Shirt Button Replacement: step 4, image 2 of 3 Dress Shirt Button Replacement: step 4, image 3 of 3
      • Put the needle through the hole diagonal and feed through to the back of the shirt
      • Repeat this process for the other diagonal.
      • Repeat the process of sewing through the diagonals multiple times.
      Ask FixBot
    5. Dress Shirt Button Replacement: step 5, image 1 of 1
      • When there is about 4 inches of thread yet, push the thread so that it is on the back side of the fabric.
      • Then push the needle back through making sure to not go through the button again.
      Ask FixBot
    6. Dress Shirt Button Replacement: step 6, image 1 of 3 Dress Shirt Button Replacement: step 6, image 2 of 3 Dress Shirt Button Replacement: step 6, image 3 of 3
      • Wrap the thread around the button 4-6 times.
      Ask FixBot
    7. Dress Shirt Button Replacement: step 7, image 1 of 3 Dress Shirt Button Replacement: step 7, image 2 of 3 Dress Shirt Button Replacement: step 7, image 3 of 3
      • Push the thread back through to the back side of the fabric.
      • Tie the knot off and cut.
      Ask FixBot
Your shirt is now ready to be worn again.
2 other people completed this guide.
Author
with
Jonathan Wong
225 Reputation
1 Guide authored
Cal Poly, Team 28-4, Green Spring 2015 Member of Cal Poly, Team 28-4, Green Spring 2015
CPSU-GREEN-S15S28G4
6 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 41
Past 30 Days: 176
All Time: 6,069
