Up to 20% off select tools
Dremel 8200 Disassembly
Views: 5.4K
View statistics:
Past 24 Hours:
10
Past 7 Days:
37
Past 30 Days:
166
All Time:
5,435
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Disassembling your Dremel 8200.
    1. Dremel 8200 Disassembly, Dremel 8200 Disassembly: step 1, image 1 of 2 Dremel 8200 Disassembly, Dremel 8200 Disassembly: step 1, image 2 of 2
      • Take off the screw cap at the top
      Ask FixBot
    2. Dremel 8200 Disassembly: step 2, image 1 of 2 Dremel 8200 Disassembly: step 2, image 2 of 2
      • Take out the battery
      Ask FixBot
      • Remove oblong belt clip
      Ask FixBot
    3. Dremel 8200 Disassembly: step 4, image 1 of 1
      • Unscrew screws
      Ask FixBot
      • Take back u clip out carefully
      • Be very careful to not injure yourself
      Ask FixBot
    4. Dremel 8200 Disassembly: step 6, image 1 of 2 Dremel 8200 Disassembly: step 6, image 2 of 2
      • The casing should just open right up and be easily accessible
      Ask FixBot
    5. Dremel 8200 Disassembly: step 7, image 1 of 1
      • You can remove the buttons except for the sliding one that adjusts the speed
      Ask FixBot
    6. Dremel 8200 Disassembly: step 8, image 1 of 2 Dremel 8200 Disassembly: step 8, image 2 of 2
      • You can take the motor out first and it will be a little hard to do so
      • Work your way down and take out each successive circuit board
      • The last thing to be out should be the sliding speed adjustment and the button for that should fall right out
      Ask FixBot
3 other people completed this guide.
Author
with
mitchellbarnhart
86 Reputation
1 Guide authored
2 Guide Comments
It will be handy to have either a can of compressed air or an air directional nozzle on your compressor. Be careful of the circuits and small parts that can blow away. You'll be amazed how even with a maintenance schedule, how much dirt will be on the motor fins
m. D. w. - Reply Share
How do you replace just the bearing in this assembly?
Andre Da Silva - Reply Share
Past 24 Hours: 10
Past 7 Days: 37
Past 30 Days: 166
All Time: 5,435
