Dremel 4000 Shaft Lock Pin Replacement
Views: 17K
View statistics:
Past 24 Hours:
6
Past 7 Days:
34
Past 30 Days:
189
All Time:
16,717
Comments: 11
8 comments on steps, 3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 6 minutes
Difficulty: Very easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This is likely the simplest repair possible for this device. Simply access the shaft lock pin after opening the case.
Parts
Tools
    1. Dremel 4000 Shaft Lock Pin Replacement, Back Case: step 1, image 1 of 2 Dremel 4000 Shaft Lock Pin Replacement, Back Case: step 1, image 2 of 2
      • Start by removing the housing cap by unscrewing it.
      • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
      • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
      Ask FixBot
    2. Dremel 4000 Shaft Lock Pin Replacement: step 2, image 1 of 1
      • Using your hands, carefully remove hanger from casing.
      Ask FixBot
    3. Dremel 4000 Shaft Lock Pin Replacement: step 3, image 1 of 2 Dremel 4000 Shaft Lock Pin Replacement: step 3, image 2 of 2
      • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
      • The brush caps are spring loaded.
      Ask FixBot
    4. Dremel 4000 Shaft Lock Pin Replacement: step 4, image 1 of 1
      • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
      Ask FixBot
    5. Dremel 4000 Shaft Lock Pin Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to gently wedge apart the hard plastic threads.
      Ask FixBot
    6. Dremel 4000 Shaft Lock Pin Replacement: step 6, image 1 of 1
      • Use your hands to carefully remove the back casing so that none of the components fall out.
      Ask FixBot
    1. Dremel 4000 Shaft Lock Pin Replacement, Shaft Lock Pin: step 7, image 1 of 1
      • If the shaft lock pin is not engaging the rotary gear, or if the spring is missing or damaged, it will need to be replaced.
      • Remove the damaged shaft lock pin and spring by hand.
      • Place new shaft lock pin so that the spring functions and the lock engages the rotary gear.
      Ask FixBot
3 other people completed this guide.
John Cobb
1,842 Reputation
4 Guides authored
USF Tampa, Team 15-4, Remmell Spring 2016 Member of USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Members
60 Guides authored
3 Guide Comments
These instructions are idiotic! I want to replace the shaft lock pin because it is not WORKING. Step 1 instructs me to use the shaft lock pin to remove the exposed collet nut. The reason I am changing the shaft lock pin is because it won’t hold the shaft for loosening the collet nut. DUH!
mitchthane - Reply Share
three years later and I came to the same conclusion: DUH
Randy Martin - Reply Share
Four years later and I came to the same conclusion: DUH
Ben simon - Reply Share
Past 24 Hours: 6
Past 7 Days: 34
Past 30 Days: 189
All Time: 16,717
