Dremel 4000 Electrical Assembly Replacement
Views: 42K
View statistics:
Past 24 Hours:
7
Past 7 Days:
58
Past 30 Days:
328
All Time:
42,271
Comments: 35
20 comments on steps, 15 guide comments.
Go to guide comments
Completed: 29
29 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace the electrical assembly in a Dremel 4000.
Parts
Tools
    1. Dremel 4000 Electrical Assembly Replacement, Back Case: step 1, image 1 of 2 Dremel 4000 Electrical Assembly Replacement, Back Case: step 1, image 2 of 2
      • Start by removing the housing cap by unscrewing it.
      • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
      • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
      Ask FixBot
    2. Dremel 4000 Electrical Assembly Replacement: step 2, image 1 of 1
      • Using your hands, carefully remove hanger from casing.
      Ask FixBot
    3. Dremel 4000 Electrical Assembly Replacement: step 3, image 1 of 2 Dremel 4000 Electrical Assembly Replacement: step 3, image 2 of 2
      • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
      • The brush caps are spring loaded.
      Ask FixBot
    4. Dremel 4000 Electrical Assembly Replacement: step 4, image 1 of 1
      • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
      Ask FixBot
    5. Dremel 4000 Electrical Assembly Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to gently wedge apart the hard plastic threads.
      Ask FixBot
    6. Dremel 4000 Electrical Assembly Replacement: step 6, image 1 of 1
      • Use your hands to carefully remove the back casing so that none of the components fall out.
      Ask FixBot
    1. Dremel 4000 Electrical Assembly Replacement, Power Cord: step 7, image 1 of 2 Dremel 4000 Electrical Assembly Replacement, Power Cord: step 7, image 2 of 2
      • To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
      Ask FixBot
    2. Dremel 4000 Electrical Assembly Replacement: step 8, image 1 of 1
      • Using your fingers, carefully pull the circuit board from the casing. This will make it easier to remove the power cord.
      Ask FixBot
    3. Dremel 4000 Electrical Assembly Replacement: step 9, image 1 of 1
      • Each wire is fed through a small opening on the circuit board and held with a flat head screw.
      • Loosen the screw just enough to remove the wire by gently pulling it with your hand.
      Ask FixBot
    4. Dremel 4000 Electrical Assembly Replacement: step 10, image 1 of 1
      • Carefully remove both wires from circuit board with your hands.
      • Take careful note of which side has the black wire and which has the white wire.
      Ask FixBot
    1. Dremel 4000 Electrical Assembly Replacement, Bearing Assembly: step 11, image 1 of 2 Dremel 4000 Electrical Assembly Replacement, Bearing Assembly: step 11, image 2 of 2
      • Carefully pull up on the shaft to lift out of the casing.
      Ask FixBot
    2. Dremel 4000 Electrical Assembly Replacement: step 12, image 1 of 2 Dremel 4000 Electrical Assembly Replacement: step 12, image 2 of 2
      • Firmly hold the field assembly in one hand and the bearing assembly in the other.
      • Carefully slide the bearing assemble out of the field assembly.
      Ask FixBot
    1. Dremel 4000 Electrical Assembly Replacement, Electrical Assembly: step 13, image 1 of 2 Dremel 4000 Electrical Assembly Replacement, Electrical Assembly: step 13, image 2 of 2
      • Firmly hold the field assembly in one hand, and carefully pull free the red and black wires that connects the electrical assembly to the field assembly.
      • Take note which slot gets the red wire and which gets the black wire for proper reassembly.
      Ask FixBot
    2. Dremel 4000 Electrical Assembly Replacement: step 14, image 1 of 1
      • This is your completely removed electrical assembly.
      Ask FixBot
29 other people completed this guide.
John Cobb
1,842 Reputation
4 Guides authored
USF Tampa, Team 15-4, Remmell Spring 2016 Member of USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Members
60 Guides authored
15 Guide Comments
One of the brush holders has a component...small capacitor... ten cent part. If somebody can identify the value of the component, I could fix mine now that I've replaced the control board and still won't start. I shorted across the component and suddenly came to life.
Tom Hartsell - Reply Share
DF110S 110c Thermal Fuse 16A 250V
“Thermal fuse DF is an one shot device, after operating function have to be replaced.”
Jozef Kutej - Reply Share
Anyone with info about the third wire (on mine is blue ending with a small copper clip) serves? This is connected off of the switch, labeled W5 on the circuit board. [Edit. It is a ground] I suspect it is a feed back wire for speed sensor? But where does it attach? Some wear on the abovementioned capacitor crossing one of the brushes. Anny ideas?
Mercedes Joy - Reply Share
You see the copper bushing slot at the top of the picture (next to the guy’s index finger) from step 9? Directly underneath it where the slot sits, there’s a tiny notch in the gray frame. Once you pull off the bushing slot from the frame (if you haven’t already), slide the small copper clip (from your 3rd blue wire) onto that notch. Then you push the bushing slot back onto the frame where it was. Essentially, the copper clip is “grounded” to that bushing slot.
louisloria - Reply Share
An even better photo in step 11 showing the copper clip on the blue wire located beneath the copper brush holder
D Lee - Reply Share
Past 24 Hours: 7
Past 7 Days: 58
Past 30 Days: 328
All Time: 42,271
