Up to 20% off select tools
Dremel 4000 Back Case Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
20
All Time:
2,293
Comments: 8
8 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This is a prerequisite guide only. In the following steps, you will remove two exterior parts, then remove the screws that hold the casing together.
    1. Dremel 4000 Back Case Replacement, Back Case: step 1, image 1 of 2 Dremel 4000 Back Case Replacement, Back Case: step 1, image 2 of 2
      • Start by removing the housing cap by unscrewing it.
      • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
      • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
      Ask FixBot
    2. Dremel 4000 Back Case Replacement: step 2, image 1 of 1
      • Using your hands, carefully remove hanger from casing.
      Ask FixBot
    3. Dremel 4000 Back Case Replacement: step 3, image 1 of 2 Dremel 4000 Back Case Replacement: step 3, image 2 of 2
      • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
      • The brush caps are spring loaded.
      Ask FixBot
    4. Dremel 4000 Back Case Replacement: step 4, image 1 of 1
      • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
      Ask FixBot
    5. Dremel 4000 Back Case Replacement: step 5, image 1 of 1
      • Use a plastic opening tool to gently wedge apart the hard plastic threads.
      Ask FixBot
    6. Dremel 4000 Back Case Replacement: step 6, image 1 of 1
      • Use your hands to carefully remove the back casing so that none of the components fall out.
      Ask FixBot
2 other people completed this guide.
Author
with
John Cobb
1,869 Reputation
4 Guides authored
USF Tampa, Team 15-4, Remmell Spring 2016 Member of USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 2,293
