Dreamax DMX-ST7A Motherboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
90
All Time:
729
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replace the tablets Motherboard.
Tools
    1. Dreamax DMX-ST7A Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • Position the tablet so the ports and screws are facing you.
      Ask FixBot
    2. Dreamax DMX-ST7A Motherboard Replacement: step 2, image 1 of 1
      • Remove the two 2.5mm screws using the Phillips #00 precision screwdriver.
      Ask FixBot
    3. Dreamax DMX-ST7A Motherboard Replacement: step 3, image 1 of 2 Dreamax DMX-ST7A Motherboard Replacement: step 3, image 2 of 2
      • Use the plastic opening tool to assist in removing the back cover.
      Ask FixBot
    4. Dreamax DMX-ST7A Motherboard Replacement: step 4, image 1 of 1
      • Upon removing the back cover position the tablet as seen in the picture.
      Ask FixBot
    1. Dreamax DMX-ST7A Motherboard Replacement, Motherboard: step 5, image 1 of 2 Dreamax DMX-ST7A Motherboard Replacement, Motherboard: step 5, image 2 of 2
      • Lift the black bars to expose the data strips.
      • Remove the data strips.
      Ask FixBot
    2. Dreamax DMX-ST7A Motherboard Replacement: step 6, image 1 of 2 Dreamax DMX-ST7A Motherboard Replacement: step 6, image 2 of 2
      • Remove the three 2.5mm screws using the Phillips #00 precision screwdriver that is holding the motherboard in place.
      Ask FixBot
    3. Dreamax DMX-ST7A Motherboard Replacement: step 7, image 1 of 2 Dreamax DMX-ST7A Motherboard Replacement: step 7, image 2 of 2
      • Remove the three wires connected to the battery along with the speaker wires from the motherboard. Then remove the motherboard from the tablet.
      Ask FixBot
    4. Dreamax DMX-ST7A Motherboard Replacement: step 8, image 1 of 2 Dreamax DMX-ST7A Motherboard Replacement: step 8, image 2 of 2
      • Install the new motherboard by soldering the speaker wires and the battery wires in their intended location. For additional soldering instructions please view this page: How To Solder and Desolder Connections
      Ask FixBot
Stacey Mattila
543 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 90
All Time: 729
