Up to 20% off select tools
Drawer Roller Bracket Replacement
Views: 2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
31
Past 30 Days:
131
All Time:
1,977
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 6 hours
Difficulty: Difficult
Introduction
Go to step 1 ↓
This project will result in an illustrated how-to guide on fixing a drawer roller bracket that does not close completely. By the end of this fix you will have a drawer that closes flush against the face of the furniture.
    1. Drawer Roller Bracket Replacement, Drawer Roller Bracket Replacement: step 1, image 1 of 2 Drawer Roller Bracket Replacement, Drawer Roller Bracket Replacement: step 1, image 2 of 2
      • Clear out drawer of any contents. This will make the drawer easier to handle, with no mess or clutter.
      • To remove, pull the drawer completely open.
      • Lift the drawer straight up.
      Ask FixBot
    2. Drawer Roller Bracket Replacement: step 2, image 1 of 1
      • Remove the brackets on the drawer.
      • Some may have rivets, some may have screws. If there are screws a simple screwdriver will do the trick. If there are rivets use a drill the size of the head of the rivet and proceed to drill the head of the rivet.
      • When removing rivets with a drill, wear eye protection and be cautious.
      Ask FixBot
    3. Drawer Roller Bracket Replacement: step 3, image 1 of 2 Drawer Roller Bracket Replacement: step 3, image 2 of 2
      • Measure the length of the internal track to the recessed part in the rear of the track.
      • This recess will hold the drawer completely closed when the wheel on the bracket reaches it.
      • Then measure the amount of bracket that needs to be removed. In our case, 2 inches will need to be removed.
      Ask FixBot
    4. Drawer Roller Bracket Replacement: step 4, image 1 of 2 Drawer Roller Bracket Replacement: step 4, image 2 of 2
      • Remove the excess bracket. Make sure to remove parts of the bracket that do not contain holes. These holes are used for fasteners.
      • To cut a section, make sure you make perfectly vertical cuts for the remaining pieces to line up. To assure a straight line to cut, use a sharpie marker to mark a straight line.
      • Use a reciprocating power saw or a grinder with cutting wheel. I used a grinder because I found it to be easier.
      • Maintain eye protection, and gloves if necessary.
      Ask FixBot
    5. Drawer Roller Bracket Replacement: step 5, image 1 of 1
      • Apply JB Kwikweld to the remaining pieces of bracket. Mix equal parts of the mixture.
      • Discard the removed piece from last step.
      • When applying JB weld, use a small amount, I used a toothpick as an applicator.
      • Set time was roughly 6 minutes for the weld mixture to set.
      • Before adding weight to the drawer, allow the weld to fully cure. This will take 4-6 hours.
      Ask FixBot
    6. Drawer Roller Bracket Replacement: step 6, image 1 of 2 Drawer Roller Bracket Replacement: step 6, image 2 of 2
      • Use a drill with a drill bit to make necessary holes for screws to sit and fasten the bracket. Use a drill bit slightly larger than shaft of screws, but smaller than the head of the screws.
      • I used a 3/32 drill bit.
      • Install new fastener screws to the bracket.
      • My build required 12 #6x1/2inch Philips screws. I used three screws on each end of the brackets and six screws on each end of the bracket.
      • The more screws used, the stronger the bracket is secured. (Two on the bottom of the bracket, and one on the inside of the track.)
      • If possible, use preexisting holes, and screws.
      • Sometimes screws protrude too far, you may have to grind the head of the screw slightly so it protrudes less.
      Ask FixBot
    7. Drawer Roller Bracket Replacement: step 7, image 1 of 1
      • Make sure the bracket is fastened securely, make any necessary adjustments.
      • You may need to grind down some of the JB Weld if too much was applied. Simply used a file or grinder.
      Ask FixBot
    8. Drawer Roller Bracket Replacement: step 8, image 1 of 1
      • Insert wheels on both sides of the drawer bracket into the opening behind the wheel on the track located in the furniture.
      • Close the drawer and make sure it opens and closes functionally.
      Ask FixBot
Author
with
Austen Schram
187 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 131
All Time: 1,977
