Draining a Toilet Tank
Views: 38K
View statistics:
Past 24 Hours:
8
Past 7 Days:
50
Past 30 Days:
251
All Time:
37,752
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Most toilet repairs are easier to perform without water in the toilet tank. Use this guide to drain the tank of a traditional gravity flush toilet.
    1. Draining a Toilet Tank, Tank Lid: step 1, image 1 of 3 Draining a Toilet Tank, Tank Lid: step 1, image 2 of 3 Draining a Toilet Tank, Tank Lid: step 1, image 3 of 3
      • Lift the tank lid up and away from the toilet tank.
      Ask FixBot
    1. Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: step 2, image 1 of 2 Draining a Toilet Tank, Shutting off the Water Supply to a Toilet: step 2, image 2 of 2
      • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
      • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
      Ask FixBot
    1. Draining a Toilet Tank, Draining a Toilet Tank: step 3, image 1 of 2 Draining a Toilet Tank, Draining a Toilet Tank: step 3, image 2 of 2
      • Push down the flush lever.
      • Hold the lever down until water stops draining from the tank.
      • A small amount of water will remain in the bottom of the tank.
      • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
      Ask FixBot
Most toilets retain a small amount of water in the tank after draining. To remove any excess water from the bottom of your toilet tank, use our guide for Sponge Drying a Toilet Tank.
Ron Davis
33,796 Reputation
13 Guides authored
2 Guide Comments
I have a cracking in my toilet tank going almost the length of the tank and below water line resulting in a leak. In your experience is a sealant a good option or in reality would the tank need to be replaced in time ?
Thanks
K EVANS - Reply Share
It would make more sense to replace the tank, than seal any crack which would only reappear after time anyway.
John Turner - Reply Share
Past 24 Hours: 8
Past 7 Days: 50
Past 30 Days: 251
All Time: 37,752
