Dragon Touch M10X Power/Volume Button Replacement
    1. Dragon Touch M10X Power/Volume Button Replacement, Power/Volume Button: step 1, image 1 of 2 Dragon Touch M10X Power/Volume Button Replacement, Power/Volume Button: step 1, image 2 of 2
      • Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
      Ask FixBot
    2. Dragon Touch M10X Power/Volume Button Replacement: step 2, image 1 of 2 Dragon Touch M10X Power/Volume Button Replacement: step 2, image 2 of 2
      • Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
      • Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
      Ask FixBot
    3. Dragon Touch M10X Power/Volume Button Replacement: step 3, image 1 of 2 Dragon Touch M10X Power/Volume Button Replacement: step 3, image 2 of 2
      • Ensure your buttons look like this
      • If either the buttons or the button holes in the back cover are dirty, clean them.
      • If the buttons are cracked or broken, they will have to be replaced
      Ask FixBot
    4. Dragon Touch M10X Power/Volume Button Replacement: step 4, image 1 of 1
      • With the old buttons removed place the new ones in
      Ask FixBot
    5. Dragon Touch M10X Power/Volume Button Replacement: step 5, image 1 of 1
      • These buttons are held in by gravity alone so when reattaching the device back on to the cover, keep it upside down.
      • Secure the bottom of the device first before closing up the sides.
      Ask FixBot
2 other people completed this guide.
Eric Megna
333 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 33
All Time: 2,129
