Doss E-GO II Motherboard Replacement
    1. Doss E-GO II Motherboard Replacement, Motherboard: step 1, image 1 of 3 Doss E-GO II Motherboard Replacement, Motherboard: step 1, image 2 of 3 Doss E-GO II Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Peel the backing off of the speaker.
      • Remove eight 7.9 mm screws using the Phillips #00 screwdriver.
      • Gently pull apart the grille on the sides of the speaker.
      Ask FixBot
    2. Doss E-GO II Motherboard Replacement: step 2, image 1 of 2 Doss E-GO II Motherboard Replacement: step 2, image 2 of 2
      • Remove seven 8 mm screws using a Phillips #00 screwdriver.
      • Remove six 7.3 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. Doss E-GO II Motherboard Replacement: step 3, image 1 of 3 Doss E-GO II Motherboard Replacement: step 3, image 2 of 3 Doss E-GO II Motherboard Replacement: step 3, image 3 of 3
      • Flip the motherboard over.
      • Use tweezers to disconnect all applicator clips.
      • Use tweezers to disconnect the white ribbon cable.
      Ask FixBot
    4. Doss E-GO II Motherboard Replacement: step 4, image 1 of 2 Doss E-GO II Motherboard Replacement: step 4, image 2 of 2
      • Use tweezers to remove applicator.
      • The motherboard is now detached and can be replaced.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 23
All Time: 321
