Doss E-GO II Charging Port Replacement
    1. Doss E-GO II Charging Port Replacement, Charging Port: step 1, image 1 of 3 Doss E-GO II Charging Port Replacement, Charging Port: step 1, image 2 of 3 Doss E-GO II Charging Port Replacement, Charging Port: step 1, image 3 of 3
      • Peel the backing off of the speaker.
      • Remove eight 7.9 mm screws using the Phillips #00 screwdriver.
      • Gently pull apart the grille on the sides of the speaker.
      Ask FixBot
    2. Doss E-GO II Charging Port Replacement: step 2, image 1 of 3 Doss E-GO II Charging Port Replacement: step 2, image 2 of 3 Doss E-GO II Charging Port Replacement: step 2, image 3 of 3
      • Remove four 7.8 mm screws using the Phillips #00 screwdriver.
      • Pull out the charging port and remove the two 7.8 mm screws using the Phillips #00 screwdriver.
      • Apply a bead of flux.
      Ask FixBot
    3. Doss E-GO II Charging Port Replacement: step 3, image 1 of 1
      • Press the soldering iron tip firmly to melt the solder.
      • If you heat the area for more than 10 seconds, the excessive heat may damage the board, port, and wires.
      • Use tweezers to remove the charging port.
      Ask FixBot
Natalie
385 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 27
All Time: 353
