Doss E-GO II Button Receptors Replacement
    1. Doss E-GO II Button Receptors Replacement, Button Receptors: step 1, image 1 of 3 Doss E-GO II Button Receptors Replacement, Button Receptors: step 1, image 2 of 3 Doss E-GO II Button Receptors Replacement, Button Receptors: step 1, image 3 of 3
      • Peel the backing off of the speaker.
      • Remove eight 7.9 mm screws using the Phillips #00 screwdriver.
      • Gently pull apart the grille on the sides of the speaker.
      Ask FixBot
    2. Doss E-GO II Button Receptors Replacement: step 2, image 1 of 2 Doss E-GO II Button Receptors Replacement: step 2, image 2 of 2
      • Remove seven 8 mm screws using a Phillips #00 screwdriver.
      • Remove six 7.3 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. Doss E-GO II Button Receptors Replacement: step 3, image 1 of 3 Doss E-GO II Button Receptors Replacement: step 3, image 2 of 3 Doss E-GO II Button Receptors Replacement: step 3, image 3 of 3
      • Apply a bead of flux.
      • Press the soldering iron tip firmly to melt the solder.
      • If you heat the circuit board constantly for more than 10 seconds, the excessive heat may damage the board.
      • Use tweezers to remove the receptor.
      Ask FixBot
    4. Doss E-GO II Button Receptors Replacement: step 4, image 1 of 1
      • Use a small piece of solder to attach a new receptor.
      • Press the tip 2 seconds on each corner to attach the receptor to the board.
      Ask FixBot
Natalie
385 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 21
All Time: 351
