Doss E-GO II Battery Replacement
    1. Doss E-GO II Battery Replacement, Battery: step 1, image 1 of 3 Doss E-GO II Battery Replacement, Battery: step 1, image 2 of 3 Doss E-GO II Battery Replacement, Battery: step 1, image 3 of 3
      • Peel the backing off of the speaker.
      • Remove eight 7.9 mm screws using the Phillips #00 screwdriver.
      • Gently pull apart the grille on the sides of the speaker.
      Ask FixBot
    2. Doss E-GO II Battery Replacement: step 2, image 1 of 2 Doss E-GO II Battery Replacement: step 2, image 2 of 2
      • Remove seven 8 mm screws using a Phillips #00 screwdriver.
      • Detach the wire connections that connect to the motherboard to have easier access to the battery.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 38
All Time: 560
