Dopo Double Power 7 Battery Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
82
All Time:
1,502
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
Skills you will need to be familiar with are soldering. Besides a new battery, you will also need access to a soldering kit.
Tools
    1. Dopo Double Power 7 Battery Replacement, Rear Panel: step 1, image 1 of 1
      • The rear panel is secured to the front case and can simply be pried apart without damage.
      Ask FixBot
    2. Dopo Double Power 7 Battery Replacement: step 2, image 1 of 1
      • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
      Ask FixBot
    3. Dopo Double Power 7 Battery Replacement: step 3, image 1 of 1
      • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
      Ask FixBot
    4. Dopo Double Power 7 Battery Replacement: step 4, image 1 of 1
      • The rear panel should come completely off.
      Ask FixBot
    1. Dopo Double Power 7 Battery Replacement, Battery: step 5, image 1 of 1
      • Cut only the red and black wires attaching the battery to the motherboard.
      • Be sure to remove any remaining wire attached to the motherboard.
      Ask FixBot
    2. Dopo Double Power 7 Battery Replacement: step 6, image 1 of 1
      • Using a metal spudger, carefully pry the battery away from the digitizer.
      • Be careful to not damage the battery. This could result in injury.
      Ask FixBot
    3. Dopo Double Power 7 Battery Replacement: step 7, image 1 of 1
      • Using wire strippers, strip the ends of the red and black wires connected to the the new battery back about a 1/8".
      • Twist the strands of the spliced wire together.
      • Using a soldering iron, apply heat to one bare wire connections you have just made.
      • When the connection is hot enough melt solder on the opposite side of the wire to the iron as shown in the image. Do not melt to much solder.
      • Once connection is made wait for it to cool off and gently pull each side of the wire to test durability.
      • Repeat this process with the other wire.
      • If you do not have access to a soldering iron, leave the old battery wires attached to the motherboard and simply splice the new battery's wires to them.
      • This video provides basic instructions for splicing wires using crimping and heat shrink technique.
      Ask FixBot
mike pelosi
682 Reputation
6 Guides authored
UMass Dartmouth, Team 1-2, Miles Fall 2015 Member of UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 82
All Time: 1,502
