Up to 20% off select tools
Doov v15 Sim Card Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
71
All Time:
573
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
A guide on how to replace a Sim Card inside of DoovV15 smartphone.
Make sure there's a sim card that matches up to the DoovV15 smartphone.
Work in a clean, well-lit area.
Use appropriate tools like a opening tool, and Jimmy.
Ensure you have the necessary safety gear to protect your eyes and hands.
Back up your data and power off the phone before you start. For additional help please use the step by step guide.
    1. Doov v15 Sim Card Replacement, Sim Card: step 1, image 1 of 1
      • Use the Jimmy to crack open the phone's back cover. Slide it under an edge of the phones back cover and carefully loosen the edge. The casing should pop open slightly.
      Ask FixBot
    2. Doov v15 Sim Card Replacement: step 2, image 1 of 2 Doov v15 Sim Card Replacement: step 2, image 2 of 2
      • Use an Ifixit opening tool and slide it around the phones back cover. The Sim Card will be visible above the battery to the right.
      Ask FixBot
    3. Doov v15 Sim Card Replacement: step 3, image 1 of 2 Doov v15 Sim Card Replacement: step 3, image 2 of 2
      • Disconnect the battery: Once the back casing is removed, the battery will be visible. Use the ifixit opening tool to remove the battery. Place the ifixit opening tool at the top of the battery and pull it back, or simply use your hand to remove it.
      Ask FixBot
    4. Doov v15 Sim Card Replacement: step 4, image 1 of 2 Doov v15 Sim Card Replacement: step 4, image 2 of 2
      • Use the Ifixit opening tool and place it in the hole above the SIM card slot and push it downwards, so the SIM card slides downward. Place the iFixit opening tool on the now more visible SIM card and slide it down for an easy removal.
      Ask FixBot
    5. Doov v15 Sim Card Replacement: step 5, image 1 of 2 Doov v15 Sim Card Replacement: step 5, image 2 of 2
      • Place the new SIM card in the slot by sliding it back in the slot, as shown in the figure (facing the sim number and code upward.)
      Ask FixBot
Author
with
Imani Williams
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 71
All Time: 573
