Door Handle Doorknob Replacement
    1. Door Handle Doorknob Replacement, How to Change an Indoor Doorknob Handle: step 1, image 1 of 1
      • Parts: (in order from left to right)
      • Short Screws
      • Latch mechanism with latch face
      • Long screws
      • Door knob with peg and screw holes (inside of the room)
      • Door knob with screw holes (outside of the room)
      Ask FixBot
    2. Door Handle Doorknob Replacement: step 2, image 1 of 1
      • Face the inside of the knob, you should see two Phillips head screws on either side of the central knob.
      Ask FixBot
    3. Door Handle Doorknob Replacement: step 3, image 1 of 1
      • Unscrew both long screws.
      Ask FixBot
    4. Door Handle Doorknob Replacement: step 4, image 1 of 1
      • Remove the door knob on both sides of the door.
      Ask FixBot
    5. Door Handle Doorknob Replacement: step 5, image 1 of 1
      • You will see the latch face plate (the rectangular piece of metal) where the latch of the door knob is located.
      Ask FixBot
    6. Door Handle Doorknob Replacement: step 6, image 1 of 1
      • Unscrew the two short screws on the latch face plate.
      Ask FixBot
    7. Door Handle Doorknob Replacement: step 7, image 1 of 1
      • Remove the latch face plate and latch mechanism.
      Ask FixBot
    8. Door Handle Doorknob Replacement: step 8, image 1 of 1
      • Push the new latch mechanism with latch face plate into the door.
      • The slanted side of the latch mechanism will be facing the direction that the door closes.
      Ask FixBot
    9. Door Handle Doorknob Replacement: step 9, image 1 of 1
      • Screw in both short screws of the latch face plate.
      Ask FixBot
    10. Door Handle Doorknob Replacement: step 10, image 1 of 1
      • Insert the door knob that goes on the inside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
      Ask FixBot
    11. Door Handle Doorknob Replacement: step 11, image 1 of 1
      • Align the door knob that goes on the outside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
      Ask FixBot
    12. Door Handle Doorknob Replacement: step 12, image 1 of 1
      • Screw in both long screws on both sides of the door knob.
      Ask FixBot
    13. Door Handle Doorknob Replacement: step 13, image 1 of 1
      • Turn the door knob to test your work.
      Ask FixBot
      • Gather your tools: A new doorknob set, drill, screwdriver
      Ask FixBot
      • Unscrew the screws on the recent knob and once unscrewed you may know take out the knob from the door.
      Ask FixBot
      • Takeout and install the new latch: Unscrew the latch assembly and remove the latch mechanism from the door. Then insert the new latch into the hole making sure it is facing the right way.
      Ask FixBot
      • Next you will be placing the exterior knob on the outside and the interior inside and will secure the screws.
      Ask FixBot
      • Check if the latch properly works and make sure the door open and closes.
      Ask FixBot
amy pantoja
121 Reputation
1 Guide authored
1 Guide Comment
Why can I not find an interior door knob set that doesn’t have a plate on the latch assembly?
Bob - Reply Share
Past 24 Hours: 11
Past 7 Days: 60
Past 30 Days: 303
All Time: 1,950
