Dog's Squeak Toy Replacement
Views: 6.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
118
All Time:
6,668
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show how to fix a stuffed animal squeak toy for a dog. These skills may work on any stuffed toy and can be very useful. Prior knowledge on sewing is recommended. A clean work space and clean, clear lighting is, also, recommended.
If the dog toy doesn’t squeak when pressure is applied to it, then it’s most likely that the squeaker portion of the dog toy is punctured. This will require replacement.
This guide will show you how to cut open the plush toy, replace the squeaker, and sew it back to it’s original state.
Tools
    1. Dog's Squeak Toy Replacement, Squeaker of a Dog Toy: step 1, image 1 of 1
      • Using scissors, cut a hole about 2 inches to expose the toys stuffing and punctured squeaker. Make the incision on the back of the toy.
      Ask FixBot
    2. Dog's Squeak Toy Replacement: step 2, image 1 of 2 Dog's Squeak Toy Replacement: step 2, image 2 of 2
      • Remove the punctured squeaker. The broken squeaker can be discarded.
      Ask FixBot
    3. Dog's Squeak Toy Replacement: step 3, image 1 of 2 Dog's Squeak Toy Replacement: step 3, image 2 of 2
      • Place the new squeaker in the middle of the dog toy.
      Ask FixBot
    4. Dog's Squeak Toy Replacement: step 4, image 1 of 1
      • After placing the new squeaker into the toy, move the stuffing around to cover the squeaker.
      Ask FixBot
    5. Dog's Squeak Toy Replacement: step 5, image 1 of 1
      • After placing the new squeaker into the toy, it's time to sew the toy back to it's new state. Thread the needle with a 6-8 inch piece of thread. This will be more than enough thread to sew the 2 inch incision.
      • After threading the needle, tie the thread so the needle doesn't come loose.
      • Threading the needle may be hard. Using a magnifying glass may help with this step.
      Ask FixBot
    6. Dog's Squeak Toy Replacement: step 6, image 1 of 3 Dog's Squeak Toy Replacement: step 6, image 2 of 3 Dog's Squeak Toy Replacement: step 6, image 3 of 3
      • Carefully sew the 2 inch hole where the squeaker was inserted.
      Ask FixBot
1 Guide Comment
Love this post. Fixed 6 of my dog's toy's.
Trixie pup - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 118
All Time: 6,668
