Dodge Durango 2004 Tail Light Bulb Replacement
  1. Dodge Durango 2004 Tail Light Bulb Replacement, Dodge Durango 2004 Tail Light Bulb: step 1, image 1 of 2 Dodge Durango 2004 Tail Light Bulb Replacement, Dodge Durango 2004 Tail Light Bulb: step 1, image 2 of 2
    • Open the car's trunk.
    Ask FixBot
  2. Dodge Durango 2004 Tail Light Bulb Replacement: step 2, image 1 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 2, image 2 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 2, image 3 of 3
    • Pry both caps out using a spudger.
    Ask FixBot
  3. Dodge Durango 2004 Tail Light Bulb Replacement: step 3, image 1 of 1
    • Carefully pull the tail light towards yourself to gain access to the wiring.
    • Do not pull the tail light too far. It is still connected to the wires and moving it too far may damage them.
    Ask FixBot
  4. Dodge Durango 2004 Tail Light Bulb Replacement: step 4, image 1 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 4, image 2 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 4, image 3 of 3
    • Locate the connector and pull the orange safety pin out.
    • After the safety pin is out, pull on the connector plug to separate it from the tail light.
    Ask FixBot
  5. Dodge Durango 2004 Tail Light Bulb Replacement: step 5, image 1 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 5, image 2 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 5, image 3 of 3
    • Remove the three Torx 15 screws that are holding the bulb carrier in place.
    Ask FixBot
  6. Dodge Durango 2004 Tail Light Bulb Replacement: step 6, image 1 of 2 Dodge Durango 2004 Tail Light Bulb Replacement: step 6, image 2 of 2
    • Remove the bulb holder piece from the tail light by gently pulling it up.
    Ask FixBot
  7. Dodge Durango 2004 Tail Light Bulb Replacement: step 7, image 1 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 7, image 2 of 3 Dodge Durango 2004 Tail Light Bulb Replacement: step 7, image 3 of 3
    • Remove the defective bulb by pulling it up.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 34
All Time: 1,689
