Diswoe Switch-01 Joystick Cover Replacement
  1. Diswoe Switch-01 Joystick Cover Replacement, Battery: step 1, image 1 of 3 Diswoe Switch-01 Joystick Cover Replacement, Battery: step 1, image 2 of 3 Diswoe Switch-01 Joystick Cover Replacement, Battery: step 1, image 3 of 3
    • Use a Phillips screwdriver to remove the two screws at the bottom of the hand grips.
    • Remove the handgrips from the controller.
    Ask FixBot
  2. Diswoe Switch-01 Joystick Cover Replacement: step 2, image 1 of 3 Diswoe Switch-01 Joystick Cover Replacement: step 2, image 2 of 3 Diswoe Switch-01 Joystick Cover Replacement: step 2, image 3 of 3
    • Turn the controller over so the bottom is facing up.
    • Use a Phillips screwdriver to remove the five screws from the back case.
    Ask FixBot
  3. Diswoe Switch-01 Joystick Cover Replacement: step 3, image 1 of 3 Diswoe Switch-01 Joystick Cover Replacement: step 3, image 2 of 3 Diswoe Switch-01 Joystick Cover Replacement: step 3, image 3 of 3
    • Use both hands to carefully remove the back cover.
    • For help removing the back cover, use a spudger to pry along the seam between the top and bottom case.
    • Don't pull the back cover off quickly or forcefully as the wires that are connected are easy to break.
    Ask FixBot
  4. Diswoe Switch-01 Joystick Cover Replacement: step 4, image 1 of 3 Diswoe Switch-01 Joystick Cover Replacement: step 4, image 2 of 3 Diswoe Switch-01 Joystick Cover Replacement: step 4, image 3 of 3
    • Push on alternating sides of the battery connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Additionally, if the previous step didn’t work, use the arms of a pair of sharp tweezers to gently push the connector out of its socket by inserting them into the cutouts.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • To reconnect the cable, insert the connector into its socket and push on the edges until it's fully seated
    Ask FixBot
  5. Diswoe Switch-01 Joystick Cover Replacement: step 5, image 1 of 2 Diswoe Switch-01 Joystick Cover Replacement: step 5, image 2 of 2
    • Remove the battery from the main circuit board.
    • The battery is held in place by sticky foam. If you aren't able to remove it easily by hand, use a spudger to gently loosen the adhesive and then remove the battery.
    Ask FixBot
  6. Diswoe Switch-01 Joystick Cover Replacement, Joystick Cover: step 6, image 1 of 1
    • Remove the PCB that is connected near the triggers and the motors at the bottom of the controller.
    • Once everything is disconnected, the motherboard can be removed.
    Ask FixBot
  7. Diswoe Switch-01 Joystick Cover Replacement: step 7, image 1 of 1
    • Clean any debris from the underside of the joystick.
    • Optional: Use dust cleaner or compressed air for best results.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Freili Estrada
106 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 77
All Time: 665
