This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓This guide shows you how to separate the display from the base of a why! V540TU by disconnecting the cables and removing the screws that connect the two parts.
Unscrew the screws circled in red.
Insert the opening pick into the gap and slide it all the way around.
Remove the adhesive from the first cable.
Remove the cable.
Remove the second adhesive.
Remove the second cable.
Lift the heat sink.
Unplug the cable connected to the motherboard.
Remove the adhesives.
Unscrew the screws circled in green.
Remove the adhesive.
Reinstall the clutch hinge.
Unplug the cable.
To reassemble your device, follow the instructions in reverse order.
