Dishwasher Water Inlet Valve Replacement
      • In order to gain access to the water valve, the bottom panel must be removed
      • The bottom panel is held on with either two or four screws, depending on the model.
      • Remove the screws, and remove the panel.
      Ask FixBot
      • In order to check the solenoid coil on the water valve, remove the wire leads that connect to the solenoid coil from the wire harness
      • These are slide-on terminal connectors attached to the ends of the wire—just pull them off.
      Ask FixBot
      • Using the ohmmeter, set the range on R × 1000, and place the probes on the solenoid coil terminals
      • The meter should read between 700- and 900-ohms resistance. If not, replace the water valve.
      Ask FixBot
      • If this screen is filled with debris, it must be cleaned out
      • Be careful not to distort the screen.
      • Use a small flat-blade screwdriver and pry out the screen. Then wash out the screen, making sure that all of the debris is removed
      • Reinstall the screen.
      Ask FixBot
      • Before removing the water valve, turn off the water supply to the dishwasher.
      • Disconnect the water supply line from the inlet end of the water valve and remove the fill hose from the outlet side
      • Remove the screws that hold the water valve to the chassis of the dishwasher
      • To install the new water valve, just reverse the disassembly procedure and reassemble.
      • Check for water leaks. If none are found, reinstall the bottom panel and restore the electricity to the dishwasher.
      Ask FixBot
Matt Zieminski
50,258 Reputation
28 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 53
Past 30 Days: 190
All Time: 2,354
