This teardown is not a repair guide. To repair your E-Reader Nintendo, use our service manual.
    1. Disassembly of the E-Reader, Remove the back of the case.: step 1, image 1 of 1
      • Facing us we have 6 gold-colored triwing screws with Y2.0 bits (5mm long screws).
      Ask FixBot
    2. Disassembly of the E-Reader, Opening the enclosure.: step 2, image 1 of 1
      • The shell retreats by itself.
      Ask FixBot
    3. Disassembly of the E-Reader, Remove the motherboard and connectors.: step 3, image 1 of 3 Disassembly of the E-Reader, Remove the motherboard and connectors.: step 3, image 2 of 3 Disassembly of the E-Reader, Remove the motherboard and connectors.: step 3, image 3 of 3
      • The motherboard is attached to a ribbon cable with a locking tab connector, so you need to pull the black part of the connector towards you.
      • Also pay attention to the connectors on the E-Reader; gravity alone holds them in place. Once the cable is disconnected, you can remove them.
      Ask FixBot
    4. Disassembly of the E-Reader, Observation of the motherboard.: step 4, image 1 of 1
      • We can now see the motherboard.
      • We have the main microcontroller.
      • Here, the Rom.
      • And there, the flash memory.
      Ask FixBot
    5. Disassembly of the E-Reader, Remove the camera part.: step 5, image 1 of 2 Disassembly of the E-Reader, Remove the camera part.: step 5, image 2 of 2
      • To continue the disassembly, we have two gold-colored screws from the PH00 (5 mm long). They keep the assembly of the LEDs and the camera.
      Ask FixBot
    6. Disassembly of the E-Reader, Remove the rest of the shell.: step 6, image 1 of 3 Disassembly of the E-Reader, Remove the rest of the shell.: step 6, image 2 of 3 Disassembly of the E-Reader, Remove the rest of the shell.: step 6, image 3 of 3
      • We only have the black part of the case left to remove, it is held by 3 gold-colored PH00 screws (5 mm long).
      Ask FixBot
Special thanks to these translators:
fr en
100%
Nothing is helping us fix the world! Want to contribute?
Start translating ›
Nothing
2,217 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 58
All Time: 58
