Disassembling the Saeco Exprelia
Views: 13K
View statistics:
Past 24 Hours:
14
Past 7 Days:
75
Past 30 Days:
230
All Time:
13,108
Comments: 11
8 comments on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
The device has to be opened for many repairs, which is shown here. The side panel with the service cover may also be removed, but this is not necessary for most repairs.
These instructions may also help with other Saeco models and with coffee makers from Philips and Gaggia—they are all made by the same manufacturer and have a very similar design.
    1. Disassembling the Saeco Exprelia, remove back cover: step 1, image 1 of 1
      • Remove all accessory parts like the water reservoir, the brewing assembly as well as the drip try.
      • Remove all coffee beans from the bean container
      • Always remove the power cord
      • Remove the two T10 Torx screws from the bottom of the rear cover.
      Ask FixBot
    2. Disassembling the Saeco Exprelia: step 2, image 1 of 1
      • Pull the back cover approximately 1 cm (3/8inch) out from the bottom and push it in an upward direction.
      Ask FixBot
    1. Disassembling the Saeco Exprelia, rear frame: step 3, image 1 of 2 Disassembling the Saeco Exprelia, rear frame: step 3, image 2 of 2
      • Remove the five T10 Torx screws as marked
      • the back frame consist of 3 pieces. Lift the top part out first, then each one of the side pieces
      Ask FixBot
    1. Disassembling the Saeco Exprelia, top cover: step 4, image 1 of 3 Disassembling the Saeco Exprelia, top cover: step 4, image 2 of 3 Disassembling the Saeco Exprelia, top cover: step 4, image 3 of 3
      • Lift the bean compartment lid and loosen the Torx T10 screw.
      • Open the water compartment lid and loosen the Torx T10 screw.
      • The lid is locked into place several times. Carefully loosen the catches and lift off the lid.
      • Note: If you only want to remove the left cover on the water compartment, all you need to do is loosen the cover a little and lift it up by about 2 cm.
      Ask FixBot
    1. Disassembling the Saeco Exprelia, left panel: step 5, image 1 of 1
      • Open the front access door.
      • Lift the top cover by about 2 cm until you can just reach the screw in the top right.
      • Remove the T10 Torx screw
      Ask FixBot
    2. Disassembling the Saeco Exprelia: step 6, image 1 of 1
      • Lift the top cover slightly upwards. It requires a fair amount of force to push the side cover upwards by about 5 mm until the hooks are released and then lift it out.
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
344,257 Reputation
317 Guides authored
3 Guide Comments
Hallo. Ich habe das Problem das ich die Antriebs Zahnräder der Brühgruppe der Saeco Exprelia HD8855 falsch eingesetzt habe. Kann mor da einer helfen?
Andre - Reply Share
Zur Orientierung hilft vielleicht das hier: Saeco Royal Cogwheel replacement, Schritt 23: Setze das graue Zahnrad beim Einbau so ein, dass die Nullmarkierung auf die Achse des weißen Zahnrads zeigt.
VauWeh - Reply Share
Past 24 Hours: 14
Past 7 Days: 75
Past 30 Days: 230
All Time: 13,108
