Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Disassembling the Philips 5000X series Shaver
View statistics:
Past 24 Hours:
13
Past 7 Days:
90
Past 30 Days:
269
All Time:
379
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Introduction
Go to step 1 ↓
The device only ran for a short time before switching off. The runtime continued to decrease despite a fresh battery charge. The suspected cause was an aged replacement battery. However, the problem was a heavily clogged shaving head.
    1. Disassembling the Philips 5000X series Shaver, Remove the shaver head: step 1, image 1 of 3 Disassembling the Philips 5000X series Shaver, Remove the shaver head: step 1, image 2 of 3 Disassembling the Philips 5000X series Shaver, Remove the shaver head: step 1, image 3 of 3
      • Simply pull the shaver head off the device with a bit of force.
      • Open the shaver head by pressing the small lever.
      • Release the blue ring by turning it slightly counter-clockwise and remove it. The gray foil can now also be removed and cleaned.
      Ask FixBot
    2. Disassembling the Philips 5000X series Shaver, Opening the Handpiece: step 2, image 1 of 3 Disassembling the Philips 5000X series Shaver, Opening the Handpiece: step 2, image 2 of 3 Disassembling the Philips 5000X series Shaver, Opening the Handpiece: step 2, image 3 of 3
      • Use a small flathead screwdriver to pry off the cover.
      Ask FixBot
    3. Disassembling the Philips 5000X series Shaver, Opening the Handpiece, Part 2: step 3, image 1 of 3 Disassembling the Philips 5000X series Shaver, Opening the Handpiece, Part 2: step 3, image 2 of 3 Disassembling the Philips 5000X series Shaver, Opening the Handpiece, Part 2: step 3, image 3 of 3
      • Slightly press the U-shaped tab outward while using your thumb to pry up the cap.
      • First the left side and then the right side.
      Ask FixBot
    4. Disassembling the Philips 5000X series Shaver, Opening the handpiece part three: step 4, image 1 of 3 Disassembling the Philips 5000X series Shaver, Opening the handpiece part three: step 4, image 2 of 3 Disassembling the Philips 5000X series Shaver, Opening the handpiece part three: step 4, image 3 of 3
      • Remove the two Torx T7 screws and lift off the black cap.
      • Pry up the next layer.
      • Caution! Do not damage the seal. Otherwise, the shaver will no longer be waterproof.
      Ask FixBot
    5. Disassembling the Philips 5000X series Shaver, Opening the handle part, part five: step 5, image 1 of 3 Disassembling the Philips 5000X series Shaver, Opening the handle part, part five: step 5, image 2 of 3 Disassembling the Philips 5000X series Shaver, Opening the handle part, part five: step 5, image 3 of 3
      Ask FixBot
    6. Disassembling the Philips 5000X series Shaver, Removing the internal assembly: step 6, image 1 of 3 Disassembling the Philips 5000X series Shaver, Removing the internal assembly: step 6, image 2 of 3 Disassembling the Philips 5000X series Shaver, Removing the internal assembly: step 6, image 3 of 3
      • The internal assembly can now be pulled out.
      • To replace the replacement battery, desolder the two solder points.
      Ask FixBot
    7. Disassembling the Philips 5000X series Shaver, Remove the charging port: step 7, image 1 of 3 Disassembling the Philips 5000X series Shaver, Remove the charging port: step 7, image 2 of 3 Disassembling the Philips 5000X series Shaver, Remove the charging port: step 7, image 3 of 3
      • The charging port is secured with two clips.
      • However, it is not possible to reach the clips from above to bend them.
      • Insert a blunt rod and press against the tabletop. The charging port should then move outward despite the clips.
      • Attempting to open the charging port or the shaver from the back will cause severe damage to the plastic housing. As a result, the seal will no longer sit correctly and the shaver will no longer be waterproof.
      Ask FixBot
    8. Disassembling the Philips 5000X series Shaver, Charging port detail: step 8, image 1 of 2 Disassembling the Philips 5000X series Shaver, Charging port detail: step 8, image 2 of 2
      • The charging port with its two pins protrudes into the PCB. They are only friction-fitted.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
Author
with
Andreas Reheis
4,374 Reputation
28 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 90
Past 30 Days: 269
All Time: 379
