Disassembling the HP Pavilion tx2500 Bezel
    1. Disassembling the HP Pavilion tx2500 Bezel, Screen Rotator: step 1, image 1 of 1
      • Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
      Ask FixBot
    2. Disassembling the HP Pavilion tx2500 Bezel: step 2, image 1 of 2 Disassembling the HP Pavilion tx2500 Bezel: step 2, image 2 of 2
      • Squeeze the latches on the battery until you hear a click. Slide out the battery.
      Ask FixBot
    3. Disassembling the HP Pavilion tx2500 Bezel: step 3, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
      • Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
      Ask FixBot
    4. Disassembling the HP Pavilion tx2500 Bezel: step 4, image 1 of 1
      • Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
      Ask FixBot
    5. Disassembling the HP Pavilion tx2500 Bezel: step 5, image 1 of 1
      • Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
      Ask FixBot
    6. Disassembling the HP Pavilion tx2500 Bezel: step 6, image 1 of 1
      • Use the plastic opening tool to disconnect the wires in the upper corners.
      Ask FixBot
    7. Disassembling the HP Pavilion tx2500 Bezel: step 7, image 1 of 1
      • Flip the laptop front side up and then use your fingers to lift up the keyboard.
      Ask FixBot
    8. Disassembling the HP Pavilion tx2500 Bezel: step 8, image 1 of 1
      • Lift up the black latch that connects the film strip to the base of the computer.
      • Use the plastic opening tool to disconnect the film strip from the base of the computer.
      Ask FixBot
    9. Disassembling the HP Pavilion tx2500 Bezel: step 9, image 1 of 2 Disassembling the HP Pavilion tx2500 Bezel: step 9, image 2 of 2
      • Rotate the screen 90 degrees and remove the base under the screen.
      Ask FixBot
    10. Disassembling the HP Pavilion tx2500 Bezel: step 10, image 1 of 1
      • Rotate the screen back towards you.
      • Lift up the convertible hinge to unclip it from the base of the computer.
      Ask FixBot
    11. Disassembling the HP Pavilion tx2500 Bezel: step 11, image 1 of 2 Disassembling the HP Pavilion tx2500 Bezel: step 11, image 2 of 2
      • Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
      Ask FixBot
    12. Disassembling the HP Pavilion tx2500 Bezel: step 12, image 1 of 1
      • Gently lift up and remove the screen.
      Ask FixBot
    1. Disassembling the HP Pavilion tx2500 Bezel, Bezel: step 13, image 1 of 3 Disassembling the HP Pavilion tx2500 Bezel, Bezel: step 13, image 2 of 3 Disassembling the HP Pavilion tx2500 Bezel, Bezel: step 13, image 3 of 3
      • Disconnect the wire from the system board using the plastic opening tool.
      • Disconnect the wire from the optical drive using the plastic opening tool.
      • Gently lift the top cover from the tablet.
      Ask FixBot
    2. Disassembling the HP Pavilion tx2500 Bezel: step 14, image 1 of 2 Disassembling the HP Pavilion tx2500 Bezel: step 14, image 2 of 2
      • Using the plastic opening tool, disconnect the plastic blue film from the tablet.
      • Disconnect the wire using the plastic opening tool.
      Ask FixBot
    3. Disassembling the HP Pavilion tx2500 Bezel: step 15, image 1 of 2 Disassembling the HP Pavilion tx2500 Bezel: step 15, image 2 of 2
      • Lift the system board from the tablet.
      • Turn the system board over and lay it flat on a soft surface.
      Ask FixBot
    4. Disassembling the HP Pavilion tx2500 Bezel: step 16, image 1 of 1
      • Gently remove the bezel from the system board.
      Ask FixBot
Sarah Naiser
336 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 97
All Time: 1,193
