Up to 20% off select tools
Disassembling the Ematic Genesis
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
74
All Time:
884
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Disassembling the Ematic Genesis, Ematic Genesis Casing: step 1, image 1 of 3 Disassembling the Ematic Genesis, Ematic Genesis Casing: step 1, image 2 of 3 Disassembling the Ematic Genesis, Ematic Genesis Casing: step 1, image 3 of 3
      • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
      Ask FixBot
    2. Disassembling the Ematic Genesis: step 2, image 1 of 3 Disassembling the Ematic Genesis: step 2, image 2 of 3 Disassembling the Ematic Genesis: step 2, image 3 of 3
      • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
      • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
      • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
      • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
      Ask FixBot
    3. Disassembling the Ematic Genesis: step 3, image 1 of 1
      • Remove back plate from screen plate and lay both down flat next to each other.
      Ask FixBot
Author
with
Justin Rohrman
745 Reputation
6 Guides authored
Baylor, Team 4-3, Williams Spring 2015 Member of Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 74
All Time: 884
