Up to 20% off select tools
Disassembling the Circuit Board
Views: 5.9K
View statistics:
Past 24 Hours:
8
Past 7 Days:
37
Past 30 Days:
183
All Time:
5,906
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide provides the steps necessary to disconnect the circuit board from the bottom plastic housing. It also goes over how to remove the heat sink and base tube in order to get to the auxiliary jack and power jack.
    1. Disassembling the Circuit Board, Cracking the Case: step 1, image 1 of 1
      • Turn the device upside down so that the three rubber pads are facing up.
      Ask FixBot
    2. Disassembling the Circuit Board: step 2, image 1 of 1
      • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
      Ask FixBot
    3. Disassembling the Circuit Board: step 3, image 1 of 1
      • Remove the heated rubber pad with a plastic opening tool.
      • Repeat steps 2 and 3 for the two remaining rubber pads.
      Ask FixBot
    4. Disassembling the Circuit Board: step 4, image 1 of 2 Disassembling the Circuit Board: step 4, image 2 of 2
      • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
      Ask FixBot
    5. Disassembling the Circuit Board: step 5, image 1 of 3 Disassembling the Circuit Board: step 5, image 2 of 3 Disassembling the Circuit Board: step 5, image 3 of 3
      • Open the device along its seam.
      • Be careful when separating the device because there are wires connecting the two seperate halves.
      Ask FixBot
    6. Disassembling the Circuit Board: step 6, image 1 of 1
      • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
      Ask FixBot
    7. Disassembling the Circuit Board: step 7, image 1 of 2 Disassembling the Circuit Board: step 7, image 2 of 2
      • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
      Ask FixBot
    1. Disassembling the Circuit Board, Circuit Board: step 8, image 1 of 2 Disassembling the Circuit Board, Circuit Board: step 8, image 2 of 2
      • Remove the three 1 cm T-10 Torx screws.
      Ask FixBot
    2. Disassembling the Circuit Board: step 9, image 1 of 1
      • Carefully press out the white base tube and push up on the circuit board.
      • Note that there is a small wire connecting the circuit board to the base.
      Ask FixBot
    3. Disassembling the Circuit Board: step 10, image 1 of 2 Disassembling the Circuit Board: step 10, image 2 of 2
      • Pull the white wire out of the hot glue.
      Ask FixBot
    4. Disassembling the Circuit Board: step 11, image 1 of 3 Disassembling the Circuit Board: step 11, image 2 of 3 Disassembling the Circuit Board: step 11, image 3 of 3
      • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
      • Remove the heat sink; it should detach from the bottom of the device.
      Ask FixBot
    5. Disassembling the Circuit Board: step 12, image 1 of 3 Disassembling the Circuit Board: step 12, image 2 of 3 Disassembling the Circuit Board: step 12, image 3 of 3
      • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
      • Turn the device so that the base tube is on top.
      • Remove the base tube by pulling up.
      • May need to cut the rubber adhesive between the base tube to the circuit board.
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
2 other people completed this guide.
Author
with
Janessa D Cabrera
547 Reputation
4 Guides authored
Cal Poly, Team 9-28, Maness Winter 2014 Member of Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 37
Past 30 Days: 183
All Time: 5,906
