Introduction
To replace the battery, you will very likely need a soldering iron and solder. Model number 9854L has the battery soldered to the + and - terminals.
Begin by removing the rubber grip along the handle.This can be done by using a thumbnail, pick or similar tool to pry up the upper edges on both sides sufficiently to grasp and pull them downwards, essentially turning it 'inside out' as you might a tight, wet stubborn sock.
12 other people completed this guide.
5 Guide Comments
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful. Thank you so much
When attempting to clean the unit, I removed the razor heads and everything fell out that I wasn't holding. How do I get them back and in what positions?
