This teardown is not a repair guide. To repair your iClicker, use our service manual.
    1. Disassembling iClicker Device, Disassembling iClicker Device: step 1, image 1 of 1
      • Behold the iclicker in all its interactive and educational beauty.
      Ask FixBot
    2. Disassembling iClicker Device: step 2, image 1 of 1
      • Place the device on a flat surface, buttons facing down.
      • Remove the battery cover and the three batteries within.
      Ask FixBot
    3. Disassembling iClicker Device: step 3, image 1 of 2 Disassembling iClicker Device: step 3, image 2 of 2
      • Remove the two visible screws using a #00 Phillips screwdriver.
      • Oops! Don't forget a hidden third screw beneath the factory label.
      • Peel back the corner of the label to reveal the hidden screw.
      • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
      Ask FixBot
    4. Disassembling iClicker Device: step 4, image 1 of 2 Disassembling iClicker Device: step 4, image 2 of 2
      • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
      • For the more resistent iclickers, a spudger may be employed to separate the pieces.
      Ask FixBot
    5. Disassembling iClicker Device: step 5, image 1 of 1
      • Your iclicker is now exposed for all its worth.
      • The back panel can be set aisde, as the remaining components are housed in the front panel.
      Ask FixBot
    6. Disassembling iClicker Device: step 6, image 1 of 2 Disassembling iClicker Device: step 6, image 2 of 2
      • Using a spudger, gently pry the battery connectors from the front panel.
      Ask FixBot
    7. Disassembling iClicker Device: step 7, image 1 of 1
      • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
      Ask FixBot
    8. Disassembling iClicker Device: step 8, image 1 of 1
      • The buttons can be easily removed from the front assembly sans spudger.
      Ask FixBot
    9. Disassembling iClicker Device: step 9, image 1 of 1
      • Don't lose the small LED cover sitting precariously in the front panel.
      Ask FixBot
    10. Disassembling iClicker Device: step 10, image 1 of 1
      • Your iclicker is now disassembled.
      Ask FixBot
1 Guide Comment
What is an iClicker ?
furbies - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 29
All Time: 8,231
