Disassembling Yamaha YPG-225 Faceplate
Views: 2.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
16
Past 30 Days:
94
All Time:
2,297
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Removing the face plate is necessary for most repairs to this device. Removing the face plate is a relatively simple process, requiring only the removal of several screws.
Tools
    1. Disassembling Yamaha YPG-225 Faceplate, Batteries: step 1, image 1 of 1
      • Turn the keyboard over so that the keys are facing the ground.
      Ask FixBot
    2. Disassembling Yamaha YPG-225 Faceplate: step 2, image 1 of 1
      • Pop the tabs on the battery casing and remove it from the back plate.
      Ask FixBot
    3. Disassembling Yamaha YPG-225 Faceplate: step 3, image 1 of 1
      • Locate the six batteries and remove them from the battery cavity.
      Ask FixBot
    1. Disassembling Yamaha YPG-225 Faceplate, Faceplate: step 4, image 1 of 1
      • Remove the six 10mm screws at the top of the backplate.
      Ask FixBot
    2. Disassembling Yamaha YPG-225 Faceplate: step 5, image 1 of 1
      • Remove the seven 12mm screws in the middle of the back plate.
      Ask FixBot
    3. Disassembling Yamaha YPG-225 Faceplate: step 6, image 1 of 1
      • Remove the eight 10mm screws from the side and the bottom of the back plate.
      Ask FixBot
    4. Disassembling Yamaha YPG-225 Faceplate: step 7, image 1 of 1
      • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
      • Flip over the keyboard.
      Ask FixBot
    5. Disassembling Yamaha YPG-225 Faceplate: step 8, image 1 of 2 Disassembling Yamaha YPG-225 Faceplate: step 8, image 2 of 2
      • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
      • Be careful when removing the face plate. There are wires attached.
      Ask FixBot
Lonnie Bissmeyer
468 Reputation
4 Guides authored
Cal Poly, Team 2-62, Propen Fall 2012 Member of Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 94
All Time: 2,297
