Disassembling Western Digital Elements SE HD case and mainboard
  1. Disassembling Western Digital Elements SE HD case and mainboard, Opening the case: step 1, image 1 of 1
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • The case can be opened easily with a plastic case opening tool. Strong finger nails and an old credit card / plastic card may work too.
    Ask FixBot
  2. Disassembling Western Digital Elements SE HD case and mainboard, Remove marked screws (T5): step 2, image 1 of 1
    • The 5 marked screws can be removed with a Torx T5.
    Ask FixBot
  3. Disassembling Western Digital Elements SE HD case and mainboard, Lift up the board: step 3, image 1 of 2 Disassembling Western Digital Elements SE HD case and mainboard, Lift up the board: step 3, image 2 of 2
    • Lift the board gently - there is only one small connector connecting the board to the hard disk case (around the yellow market space).
    • On the second image, you can see the board turned over.
    • Further disassembly would damage the disk. I hoped to find a SATA connector within, but maybe someone knows an alternative board with the same connector.
    Ask FixBot
  4. Disassembling Western Digital Elements SE HD case and mainboard, Hard disk labels and case labels: step 4, image 1 of 2 Disassembling Western Digital Elements SE HD case and mainboard, Hard disk labels and case labels: step 4, image 2 of 2
    • The label on the WD Elements SE case and the labels on the harddisk can be seen here. I censored serial numbers, the WWID and the barcodes.
    Ask FixBot
2 other people completed this guide.
Bastli
310 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 70
Past 30 Days: 246
All Time: 3,278
