Disassembling Unihertz Jelly (Pro) Mainboard | UART Access
    1. Disassembling Unihertz Jelly (Pro) Mainboard | UART Access, Start with back cover and battery removed: step 1, image 1 of 1
      Ask FixBot
    2. Disassembling Unihertz Jelly (Pro) Mainboard | UART Access, Remove screws: step 2, image 1 of 1
      • Remove the six Phillips-head screws in the back casing. One screw in the battery compartment might be hidden under a white sticker!
      Ask FixBot
    3. Disassembling Unihertz Jelly (Pro) Mainboard | UART Access, Remove back casing: step 3, image 1 of 1
      • Starting on one side, lift the back casing up. There are little slots around the casing to use for prying.
      Ask FixBot
    4. Disassembling Unihertz Jelly (Pro) Mainboard | UART Access, Loosen all connections: step 4, image 1 of 1
      • Remove the loose sitting power and volume push buttons. The underlying button boards are glued to the inner plastic casing. Squeeze something in between to loosen them. They remain attached to the board and will need to get out with it.
      • Next to the volume buttons there is a small connector. Fold up the bracket to release the cable.
      • Detach the display cable in the center of the board.
      • Make sure the front-facing camera and the microphone on the bottom are loose. They remain attached to the board and will need to get out with it.
      Ask FixBot
    5. Disassembling Unihertz Jelly (Pro) Mainboard | UART Access: step 5, image 1 of 1
      • Starting on one side, pry the board out of the little plastic clips.
      • Carefully lift the board up and flip it over. Have a look for the screen connecting cable - it might stick a little to the screen-facing side of the mainboard.
      Ask FixBot
    6. Disassembling Unihertz Jelly (Pro) Mainboard | UART Access: step 6, image 1 of 2 Disassembling Unihertz Jelly (Pro) Mainboard | UART Access: step 6, image 2 of 2
      • There it is.
      • If you are looking for UART: On the screen-facing side of the mainboard the pair of contact points right next to the USB port match Tx and Rx!
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure not to leave any dust or fingerprints behind, especially regarding the camera lenses.
juanos
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 107
All Time: 589
