Disassembling Trek 820 Tire Removal from Wheel
Views: 1.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
91
All Time:
1,845
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
This guide shows how to remove the tire from the wheel of a Trek 820 bicycle. When diagnosing a tire that does not stay inflated, removing the tire allows for easier and more thorough inspection of the inner tube, sealing surfaces, and other potential damage. No special skills or tools are required, although purpose-made bicycle tire removal tools are available that may make the job easier. This guide will show how to remove the tire without any special tools.
Tools
    1. Disassembling Trek 820 Tire Removal from Wheel, Tire: step 1, image 1 of 1
      • Locate the valve stem and remove the valve stem cap if one is present.
      Ask FixBot
    2. Disassembling Trek 820 Tire Removal from Wheel: step 2, image 1 of 1
      • Begin releasing tire air pressure by pressing down on the small rod in the center of the valve stem. A hissing sound will indicated that air is leaving the tire.
      • Continue to release air until the tire becomes soft and flexible. The hissing sound should become quiet or stop altogether.
      Ask FixBot
    3. Disassembling Trek 820 Tire Removal from Wheel: step 3, image 1 of 2 Disassembling Trek 820 Tire Removal from Wheel: step 3, image 2 of 2
      • Insert the flathead screwdriver, or another sturdy, long object, between the edge of the tire and the wheel rim.
      • Be careful not to damage the inner tube when inserting and moving the screwdriver or other tool. The inner tube is fragile and may be pinched between the wheel rim and tool.
      • Work the edge of the tire out of the wheel rim using a screwdriver, pulling the edge of the tire away from the center of the wheel and out of the rim.
      Ask FixBot
    4. Disassembling Trek 820 Tire Removal from Wheel: step 4, image 1 of 3 Disassembling Trek 820 Tire Removal from Wheel: step 4, image 2 of 3 Disassembling Trek 820 Tire Removal from Wheel: step 4, image 3 of 3
      • Continue around the wheel rim until the whole tire is free from the rim. Now you may separate the tire from the wheel.
      • Be careful not to damage the valve stem as you pull the tire and inner tube off of the wheel rim together.
      Ask FixBot
    5. Disassembling Trek 820 Tire Removal from Wheel: step 5, image 1 of 2 Disassembling Trek 820 Tire Removal from Wheel: step 5, image 2 of 2
      • Remove the inner tube from the tire by simply pulling it from the tire carcass.
      Ask FixBot
For tire reinstallation, simply follow these steps in reverse order.
Kaveh Karimiyanha
822 Reputation
7 Guides authored
Cal Poly, Team 1-1, Propen Fall 2012 Member of Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Members
84 Guides authored
1 Guide Comment
Be very careful using a screwdriver to unseat the tire as it is very likely you will pinch and thus ruin the tube. Better to buy several tire levers at any bike shop - they are inexpensive and made for this job.
John Sinclair - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 91
All Time: 1,845
