Up to 20% off select tools
Disassembling TI-36X Pro Back Cover
Views: 2.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
111
All Time:
2,859
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
For this guide you will remove six screws in order to remove the back cover.
    1. Disassembling TI-36X Pro Back Cover, Back Cover: step 1, image 1 of 2 Disassembling TI-36X Pro Back Cover, Back Cover: step 1, image 2 of 2
      • Remove the calculator's protective cover.
      • Place the calculator face down.
      Ask FixBot
    2. Disassembling TI-36X Pro Back Cover: step 2, image 1 of 2 Disassembling TI-36X Pro Back Cover: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the six 6mm screws from the back of the case and place them to the side.
      • Start from the notches on the top edge and use your fingers or a prying tool to carefully pry the back cover from the calculator.
      Ask FixBot
Author
with
Robert Sekerak
667 Reputation
4 Guides authored
Cal Poly, Team 11-52, Amido Spring 2014 Member of Cal Poly, Team 11-52, Amido Spring 2014
CPSU-AMIDO-S14S11G52
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 111
All Time: 2,859
