Up to 20% off select tools
Disassembling Speak And Spell Case
Views: 6.2K
View statistics:
Past 24 Hours:
7
Past 7 Days:
30
Past 30 Days:
111
All Time:
6,202
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Disassembling Speak And Spell Case, Case: step 1, image 1 of 2 Disassembling Speak And Spell Case, Case: step 1, image 2 of 2
      • Flip the toy over, so that the keypad is facing away from you.
      • Remove two Phillips-head screws.
      • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
      • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
      • This requires quite a bit of force; be careful.
      Ask FixBot
    2. Disassembling Speak And Spell Case: step 2, image 1 of 1
      • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
      Ask FixBot
bushing
10,574 Reputation
13 Guides authored
1 Guide Comment
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - Reply Share
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 111
All Time: 6,202
