Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
110
All Time:
982
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Phillips #000 Screwdriver
    4.9
  • Spudger
    4.9
    1. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Back Panel: step 1, image 1 of 1
      • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
      Ask FixBot
    2. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: step 2, image 1 of 1
      • Slide the back cover off by pushing it to the left, away from the side that held the screws.
      • Remove the cover.
      Ask FixBot
    3. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: step 3, image 1 of 1
      • This is what the device should look like once the back cover panel has been removed.
      Ask FixBot
    1. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Power Button: step 4, image 1 of 1
      • Remove the stylus from the device.
      Ask FixBot
    2. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: step 5, image 1 of 3 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: step 5, image 2 of 3 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: step 5, image 3 of 3
      • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
      • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
      • Pry apart off the top panel of the device.
      Ask FixBot
    1. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Side and Bottom Panel: step 6, image 1 of 2 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel, Side and Bottom Panel: step 6, image 2 of 2
      • Using a Phillips head screwdriver, remove the two 1.4 mm screws from the bottom panel of the device.
      • Using the same screwdriver, remove the 1.4 mm screw that is located on the back of the device.
      Ask FixBot
    2. Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: step 7, image 1 of 2 Disassembling Sony Reader Touch Edition PRS-600 Side and Bottom Panel: step 7, image 2 of 2
      • Pull the panel away from the device. You may have to use the flat end of the spudger to remove the side portion of the panel because it will be glued in place.
      Ask FixBot
Zachary Jeffers
412 Reputation
4 Guides authored
Clemson, Team 1-4, Benson Fall 2014 Member of Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 110
All Time: 982
